| How do I make my wipers park t'other side? http://international2cvfriends.com/forum/viewtopic.php?f=7&t=1428 |
Page 1 of 2 |
| Author: | samfieldhouse [ March 6th, 2010, 2:40 pm ] |
| Post subject: | How do I make my wipers park t'other side? |
As the title says really. How do I get the wipers to park on the opposite site. I know its something to do with turning something 180 degrees? |
| Author: | Russell [ March 6th, 2010, 2:45 pm ] |
| Post subject: | Re: How do I make my wipers park t'other side? |
yes, the car. Turn it round 180 degrees and the wipers will be the other side. In all seriousness, can somebody (maybe you sam?) take some pictures and do a little write up of the process please? |
| Author: | bertiewhite [ March 6th, 2010, 2:47 pm ] |
Sam, take the whole linkage unit out and you should be able to work it out. It really is just a case of undoing the spigot that the 2 linkages attach to and then turning it 180 degrees as you suggest. |
| Author: | Jonathan [ March 6th, 2010, 3:15 pm ] |
I will say, having had it altered on my car, the wiper mechanism protrudes across the drivers-side vent. You may or may not like that, because it blocks airflow and looks a bit 'wrong'. No idea how it was done though, ask Spanners |
| Author: | Neil [ March 6th, 2010, 3:16 pm ] |
Hopefully this will help: Attachment: scan0002.jpg |
| Author: | ken [ March 6th, 2010, 4:20 pm ] |
On a 2CV, using some keyhole (or should that be vent flap?) surgery, it's possible to switch the wipers over. No such luck on any other A series model, though... ken |
| Author: | samfieldhouse [ March 6th, 2010, 8:50 pm ] |
Russell wrote: yes, the car. Turn it round 180 degrees and the wipers will be the other side. In all seriousness, can somebody (maybe you sam?) take some pictures and do a little write up of the process please? Will do. I've booked some time off at the end of the month to fettle so after I've done the king pins I might have a go at this. The seal on my new vent flap is bulging because I did it up too tightly so will have a go at remedying that too. Sam |
| Author: | Neil [ March 6th, 2010, 8:53 pm ] |
samfieldhouse wrote: Russell wrote: yes, the car. Turn it round 180 degrees and the wipers will be the other side. In all seriousness, can somebody (maybe you sam?) take some pictures and do a little write up of the process please? Will do. I've booked some time off at the end of the month to fettle y0, did you not see the scan above? ^^ |
| Author: | samfieldhouse [ March 6th, 2010, 8:59 pm ] |
that will be brilliant |
| Author: | Neil [ March 6th, 2010, 9:00 pm ] |
