 How do I make my wipers park t'other side?
Post How do I make my wipers park t'other side?
As the title says really. How do I get the wipers to park on the opposite site. I know its something to do with turning something 180 degrees?
March 6th, 2010, 2:40 pm
Post Re: How do I make my wipers park t'other side?
yes, the car. Turn it round 180 degrees and the wipers will be the other side.
In all seriousness, can somebody (maybe you sam?) take some pictures and do a little write up of the process please?
March 6th, 2010, 2:45 pm
Sam, take the whole linkage unit out and you should be able to work it out. It really is just a case of undoing the spigot that the 2 linkages attach to and then turning it 180 degrees as you suggest.
March 6th, 2010, 2:47 pm
I will say, having had it altered on my car, the wiper mechanism protrudes across the drivers-side vent. You may or may not like that, because it blocks airflow and looks a bit 'wrong'. No idea how it was done though, ask Spanners ;)
March 6th, 2010, 3:15 pm
Hopefully this will help:
March 6th, 2010, 3:16 pm
On a 2CV, using some keyhole (or should that be vent flap?) surgery, it's possible to switch the wipers over. ;)
No such luck on any other A series model, though...
March 6th, 2010, 4:20 pm
Will do. I've booked some time off at the end of the month to fettle so after I've done the king pins I might have a go at this.
The seal on my new vent flap is bulging because I did it up too tightly so will have a go at remedying that too.
Sam
March 6th, 2010, 8:50 pm
y0, did you not see the scan above? ^^
March 6th, 2010, 8:53 pm
that will be brilliant :D I'll take some extra pics... how hard can it be?
March 6th, 2010, 8:59 pm
:roll:
March 6th, 2010, 9:00 pm
