View unanswered posts | View active topics It is currently April 29th, 2026, 2:39 am
Reply to topic  [ 9 posts ]
 Quick Suspension Question
Post Quick Suspension Question
Hi there
I understand how the rear trailing arms 'bounce' up and down - but how do they 'sway' from side to side - ie. the camber?
thanks all
March 8th, 2010, 5:01 pm
Post Re: Quick Suspension Question
Sorry to hi-jack Will but I also have a quick suspension question:
I'd like my car high at the back, lower at the front. If I turn the back up a bit, will that mean when I'm towing/have a car full of gear, she'll sit more level, rather than having the 'Betty' effect?
March 8th, 2010, 6:35 pm
should do I think
March 8th, 2010, 6:41 pm
Billy Basic question here: how do I change the height of the suspension (either up or down)?
March 8th, 2010, 6:45 pm
See Russ' excellent thread at the top of the technical page on '2cv suspension, everything you need to know'
March 8th, 2010, 7:19 pm
Willami wrote:
Hi there
thanks all
You're going to have to elaborate here. Rear arms have no adjustment and aside from rotating 'up and down' around the axle there should be no other movement. Camber/toe in/out not adjustable from the factory. Arms can be bent quite happily, as long as you have an old wheel, a welder and a scaffold tube.
March 8th, 2010, 7:55 pm
Willami wrote:
Hi there
thanks all
i think you can put my post as "dumbest question of the year" - i was thinking about it and looking at the schematics of the suspension system, i realised what a stupid question it was....
i jacked the car up and thought i sensed the wheel moving out a touch as the jack took the final bit of weight of the wheel...but there's no play in the wheel and no noises (trying to solve some outer tread wear)
cheers Russell anyway
Will
March 8th, 2010, 10:03 pm
Hard cornering :lol:
March 8th, 2010, 10:10 pm
Willami wrote:
Willami wrote:
Hi there
thanks all
Will
Maybe no play in the wheel, but what about the arm bearing? If it's moveing and it isn't the whel bearing, the only thing it can be, i think, is the arm bearing. All I can think of otherwise is axle bolts but I can't see that myself.
March 8th, 2010, 10:39 pm
Users browsing this forum: No registered users and 105 guests
