View unanswered posts | View active topics It is currently April 30th, 2026, 2:44 pm
 Front windows
Post Front windows
Has anyone come up with a good idea as to how to hold the front windows slightly open, other than with the bent wire devices available which to me seem rather crude.
When I bought my 2cv they were fitted but get in the way when the windows are shut and are a pain to fix when on the move.
With all the brilliant minds here, there surely must be someone with an original and superior design?
Thanks
March 4th, 2010, 10:03 am
Post Re: Front windows
A leaf blower, fixed perpendicular to the dashboard, makes a very effective 2CV window holder-opener device, I'm told.
One would require two of these contraptions if considering the needs of the front passenger. Four if one owns a Slough car.
Other than that, an elbow, strategically placed, is an excellent solution to the window-held-slightly-open problem.
March 4th, 2010, 10:57 am
Ok, that's set the tone for this thread! Maybe you can also suggest a cheap supplier of electrical cable so that I can plug the blowers in before I leave home. Shouldn't need much more than a few km's.
Tried the elbow approach but found it rather painful at speed when the window suddenly swings up and returns a blow to the elbow in revenge.
March 4th, 2010, 11:05 am
A Dyane is the solution if you want slightly less crude failing that a visa or an ax :lol:
March 4th, 2010, 11:15 am
Wouldn't the Diane stick out rather a lot when I try to wedge it between the door and the open window?
March 4th, 2010, 11:20 am
I use these simple but it works. Just turn the 'bent wire device' around so the loop bit slots over the centre of the sucker bit
https://displays-2-go.co.uk/images/Suck ... r_Hook.jpg
March 4th, 2010, 11:37 am
Now that's what I call original. Thanks for the tip.
March 4th, 2010, 11:44 am
Yes, the Dyane solution would stick out too far, and would also unbalance the 2cv... Unless you balanced it with either counterweights, cantelevers, or another Dyane, I suppose.
There's no need for electrical cabling for the leaf blowers IF you choose the petrol-driven alternatives that are widely available.
Elbow approach: carpet, or elbow pads for skateboarders, snowboarders, motorcyclists etc are very effective against window-revenge.
Actually, and I'm getting very giddy with silliness now, I've always remedied "window flapping" by opening the windscreen vent a tad. This provides just enough through-draft to keep the windows stably ajar. On cooler days this can make the hands a bit chilly, but I always keep a pair of cheap fleecy gloves in the car for this eventuality.
March 4th, 2010, 11:45 am
Steady on Snowy, you'd better go and have a lie down - you're beginning to sound quite sensible. (Which would appear rather out of character for most of the users)
March 4th, 2010, 11:49 am
I think the only problem with the wire devices is that when one drives over a bump, the window is often jarred open. Easy to reattach the wire with one hand though. Elbows on window ledge? Surely not........ :o
March 4th, 2010, 11:54 am
