Reply to topic  [ 9 posts ]
 Dyane window Latch
Spellin Bea
Post Dyane window Latch
Hi all
having great fun with the Dyane, but the maybe a little security problem. As the release latch on the passenger window is broken, you turn it and but the whole twisty bit (in the pic below) just spins and the pin doesn't move, also i can push the pin through and it just wont lock.
do i just replace it (but were the hell do i get another one) and can i fix it
Thanks George :)
February 24th, 2010, 11:02 pm
Post Re: Dyane window Latch
I think you can tighten it up a bit, but the thread is left handed.
Some, none or all of this post is wrong, incorrect or based on warped memories, many of which have been erased fully or partially by the rigours of drink and time.
February 24th, 2010, 11:05 pm
If you can hold the little collar piece on the inside of the window and then turn the catch anti-clockwise, it should tighten up on the glass and work again..... :ugeek:
February 24th, 2010, 11:06 pm
Spellin Bea
see thats what i was doing before spanners, but you see me mother turned :roll: it and now is just keeps spinning and even if you hold the collar and REALLY try to turn it it the pin does move :?
February 24th, 2010, 11:11 pm
Old Bloke
I see they are out of stock at ECAS.
This firm has them [bit expensive]
http://www.ami-2cv.com/index.php/pieces ... yane-ami-8
I think they deliver to the UK but if they don't I could get them and post them on.
Now known as 602
http://www.2CVTech.co.uk
February 24th, 2010, 11:18 pm
Spellin Bea
Flipping heck bit too much for me, thanks for looking tho
February 24th, 2010, 11:26 pm
Old Bloke
No probs.
At least you know they are still available if push comes to shove.
Now known as 602
February 24th, 2010, 11:27 pm
I've just ditched my back sliding windows, if you want the latch from them?
Spellin Bea
ooh if there the same that be great Russ :D
February 24th, 2010, 11:30 pm
