| Washer pump inlet/outlet http://international2cvfriends.com/forum/viewtopic.php?f=7&t=1376 |
Page 1 of 1 |
| Author: | Old-Nail [ February 23rd, 2010, 4:52 pm ] |
| Post subject: | Washer pump inlet/outlet |
I've only just noticed that the two prongs on the back of the windscreen washer pump are different. One is taller and the other has a bigger hole. Anyone know which is the inlet of those two before I take a 50-50 guess... and lose |
| Author: | Little Louis [ February 23rd, 2010, 6:18 pm ] |
| Post subject: | Re: Washer pump inlet/outlet |
pump it with your finger over one of the holes and see if one of them sucks? |
| Author: | PeteMcFlurry [ February 23rd, 2010, 6:31 pm ] |
well i'd guess the one with the bigger hole would be the inlet, taking x volume in at low pressure, pumping it through a smaller hole making it higher pressure? |
| Author: | bertiewhite [ February 23rd, 2010, 6:39 pm ] |
I was going to say - I stuck some bits of tubes on mine and tried each in a jar of water. |
| Author: | Old-Nail [ February 23rd, 2010, 7:16 pm ] |
PeteMcFlurry wrote: well i'd guess the one with the bigger hole would be the inlet, taking x volume in at low pressure, pumping it through a smaller hole making it higher pressure? I'll go with that thanks. |
