View unanswered posts | View active topics It is currently April 30th, 2026, 2:51 pm
Reply to topic  [ 5 posts ]
 Dash panel wiring help.
Post Dash panel wiring help.
I'm nearly there (I think) with the wiring on my car now and I've dug out and connected up the turn signal and high beam wiring too, can someone please ID which is the correct wire to connect to the brake test terminal shown in the photo below?
I took a photo of the wiring before I undid it, and I labelled most of it too so I'm pretty confident that most of it is where it should be, but I've still finished up with two wires and only one connection left!
This is the view from another angle if that's any better.
And this is how it looked when I first undid it. Any ideas?
Both the wires I have 'left over' are purple female connectors, one on green wire one on grey.
February 23rd, 2010, 4:47 pm
Post Re: Dash panel wiring help.
One of them would be for the voltmeter (club dash.).
February 23rd, 2010, 7:31 pm
green wire Voltmeter
grey wire warning lamp.
February 23rd, 2010, 7:33 pm
And it probably makes no odds (being just a switch) but in mine the connections on the fog lamp switch were the other way around.
February 23rd, 2010, 7:38 pm
Louise you're a star - thank you. That's what's been puzzling me, the voltmeter wire was surplus originally but I thought I'd missed something.
February 23rd, 2010, 8:45 pm
