View unanswered posts | View active topics It is currently April 29th, 2026, 12:11 am
Reply to topic  [ 5 posts ]
 Flasher and main beam warning lights.
Post Flasher and main beam warning lights.
I've done a quick search but can't find any reference here to fitting these?
As it stands I've fitted one of each warning lights to the blanks, and have located one brown, and one green wire tied up behind the dash.
Question:- Is just the one single wire to each lamp enough? The bulb holders have two contacts at the bottom. Oh...and which is which?
February 23rd, 2010, 12:15 am
Post Re: Flasher and main beam warning lights.
nope they are for one warning lamp. there will be (may be) another pair.
February 23rd, 2010, 12:16 am
Thanks Louise I'll have another rummage then. How do you tell which is which?
February 23rd, 2010, 12:18 am
erm I pluged them in..
I think the none test-it trace it way was to see if one was linked to the other indicator-y wires. But hey, I'm only a spark! :P :oops:
February 23rd, 2010, 12:23 am
browns are earth ( for the rest of the loom thats causing confusion at the moment the +ves or feeds are always female bullits the -ves, returns, grounds are always male. So when they fall apart there is no chance of the live wires shorting)
green is the indicator teltale
there is a spare pair brown and blue for the hi beam teltale
February 23rd, 2010, 12:28 am
Users browsing this forum: No registered users and 78 guests
