View unanswered posts | View active topics It is currently April 28th, 2026, 9:23 pm
 Water in footwell
Post Water in footwell
Hi all
What would the most likely source of water leaking in to the foot-well near the front of the front doors? Door seal? Hood?
Thanks
Justin
Charlie is gone. Now 2CVless.
February 3rd, 2010, 9:09 pm
Post Re: Water in footwell
viewtopic.php?f=7&t=1076
Maybe some help here ^
February 3rd, 2010, 9:13 pm
Thanks.
February 3rd, 2010, 9:19 pm
Water is pushed in around the wiper spindles, air went and bonnet hinge body side. Underneath the windscreen (not visable) is a small gutter draining water to both door posts. From here is runs down the door post underneath the rubber mats and it stays there. Best advise is to toss out the rubber mats and replace them with carpet and drill 2 holes in the floors both sides, for the water to get out. Also do the chassis underneath the steering rack to let the water out from inside the chassis. Have a good look at the front of the chassis, its open and it drinks water.
February 3rd, 2010, 10:43 pm
Press all over the rubber for the windscreen. It should be smooth and even all the way round. Anything else is a hole in the metal underneath it - and that's by far and away the most likely...
February 3rd, 2010, 10:59 pm
Viking,
I'm with you about drilling holes in the floors, since I do that every time I fit new ones, but don't understand why you'd recommend using carpet... :roll:
Doesn't that simply soak up the water and stay damp for ever and a day?
My solution is to keep the rubber mats but fit plastic mesh, bought from a garden centre, underneath the rubber.
This provides ventilation between the rubber mat and the floors and allows any trapped moisture to dry out...
February 4th, 2010, 12:01 am
Hmm plastic mesh another ruddy good idea :) What is the mesh for in garden centres ,so i know what to aim for .. i too get mystery water and have drilled holes but of course the rubber mat keeps it wet if i forget to lift it and check.
February 4th, 2010, 12:07 am
Hmmm,
double post, see below.
February 4th, 2010, 12:27 am
Ben,
tbh, I used to buy plastic draining board mats from stores such as Wilkos, but they've gone all upmarket and don't stock 'em any more.
If you look for plant support mesh, something like this should turn up.
< http://cgi.ebay.co.uk/NETLON-CLIMBING-P ... _500wt_975 >
or you could just raid the garden shed, like I do when the resident gardener isn't around... :lol:
February 4th, 2010, 12:28 am
ken wrote:
Viking,
Carpet absorb the water, the heat from the firewall duct will evaporate and dry the carpet if you allow the airvent or side window open. Any rubber covering water can not escape and will stay wet. I don't like rubber mats at all, bad news for floors and chassis. Best is not to have anything at all but it doesn't ''feel'' right.
February 4th, 2010, 12:39 am
Users browsing this forum: No registered users and 108 guests
