View unanswered posts | View active topics It is currently April 28th, 2026, 7:46 pm
 Heater Tubes - making a junction
Post Heater Tubes - making a junction
Hello
I'll try not to ramble this time
does anyone know what i could use as a T-junction on heater tubes, or if indeed there are ones are on a the market?
this is to use on standard ECAS heater tube - concertina type....
cheers again
Will
January 4th, 2010, 4:58 pm
Post Re: Heater Tubes - making a junction
would a plastic household waste pipe fitting fit ?
January 5th, 2010, 11:52 pm
GAFFER TAPE!
January 6th, 2010, 12:26 am
Combining Chris's suggestion & Adrian's, plus some of these bits?
< http://www.screwfix.com/cats/101310/Plu ... Syst-Black >
The 92.5º offset bend works OK for easing the alignment of the driver's side demist tube on RHD 2CVs, so should be OK with the main heater tubes.
January 6th, 2010, 1:15 am
cheers chaps - screwfix can be really great sometimes
i'll let you know how i get on - marrying M28 cowling pipes to the Ami bulkhead junction (where you can switch between screen or feet) is going to be a challenge
are M4 and M28 heater cowlings interchangeable - maybe it would be easier to do that????? anyone know???
keep warm
Will
January 6th, 2010, 3:51 pm
Not even close.
January 6th, 2010, 3:52 pm
toomany2cvs wrote:
Not even close.
quick and concise as ever :lol:
cheers mate
January 6th, 2010, 3:59 pm
50mm TEE fitting Try WWW. Toolstation .com havnt used screwfix for 4 years getting to dear toolstation better prices
January 6th, 2010, 6:19 pm
I'm not sure, but I don't think the bulkhead side of the heater system of an ami6 is the same for both m28 and m4 engines, certainly there's no way the heat exchangers from an m28 2cv fit an m4 ami6, and even modified to fit there's no way of easily plumbing them in as they exit in completely the wrong place. If you're fitting m28 heat exchangers to a previously m4 car, don't forget to cut holes in the inner wings for dump tubes (like I havent done yet...)
January 6th, 2010, 8:00 pm
hi
i've got to work with what i've got really. i think i'm going to have to make a junction out of tin cans - the standard steel tin can is a good fit into the pipes. it's getting the NS pipe from the cowling to the junction that's going to be tricky - and using the existing 'switch junction' is almost impossible as the rear brake pipe / master cylinder isn't allowing it at all....which is a shame as i wanted to get warm air to my feet to dry out any wet....
EDIT - I'VE JUST LOOKED AT YOUR AMI PHOTOS RUSS & IT SEEMS I'D FORGOTTEN ABOUT THE O/S HOLE UNDER THE BATTERY TRAY....SO I CAN USE THAT TO GET SOME WARM AIR TO THE FEET....
once it's done - i'll post some photos up
cheers
will
January 8th, 2010, 11:20 am
Users browsing this forum: No registered users and 84 guests
