Reply to topic  [ 6 posts ]
 Airbox Options
Post Airbox Options
Hi all,
Top of airbox has had it's day as lugs worn off & does not sit in place.
Quite happy to have it taped down but I am curious...
Do people ever replace the airbox housing with K&N filters or something?
Does it mess up performance.?
Curious...otherwise I will source new cover from a breakers yard.
Regards
CBI ;)
December 14th, 2009, 11:22 pm
Post Re: Airbox Options
http://www.ecas2cvparts.co.uk/filter-co ... -1150.html
Take a look at this replacement for the original.
December 15th, 2009, 12:05 am
You are probably thinking about this:
http://www.ecas2cvparts.co.uk/green-spo ... p-700.html
or this:
http://www.ecas2cvparts.co.uk/sports-fi ... p-951.html
Expert opinion seems to be that they don't make an otherwise standard 2CV any faster, they just make more noise.
December 15th, 2009, 3:12 am
or you could fix it like I was shown once (cheers Ken). ;)
Drill a hole through the lid in the centre, same in the bottom and put some threaded bar with a nut and washer either side through the bottom hole then put the lid on and put a washer and nut on to hold the lid down.
December 15th, 2009, 10:02 am
I just have three self tapping screws holding my air filter top in place(till I can get a new one).
December 15th, 2009, 12:12 pm
I'm using these (look a like) K&N airfilters for several years now
My engine is a Visa 652 and then a original airbox is to small the motor doesn't have it's original power. The original visa airbox is to big and has lots of gadgets wich I don't want, These K&N airfilters are fine and they give maximum power.
By the way the one on the picture is a motor with LPG injection. 602cc. So its the original 2cv engine and its runs very fine with this airfilter.
You can see a little video with the airfilter here.
http://www.youtube.com/user/www2cv4x4nl ... oEY5LSovEI
When you use thes filters you must make a connection in the filter for the hose coming from the oilfillcap (vacuum for the engine to keep the oil inside).
And yes they make more noise/great sound just what you like to hear, its the same sound like when you pick the original airfilter out of the airbox.
December 16th, 2009, 7:31 pm
