View unanswered posts | View active topics It is currently April 29th, 2026, 4:08 pm
Reply to topic  [ 5 posts ]
 2cv dimensions
Post 2cv dimensions
Anyone got a Haynes manual to hand, I am looking for the following dimensions...
Front track (wheel centre to wheel centre) mm
Rear track (same as above) mm
Front to Rear wheel centers mm
thanks
December 7th, 2009, 10:34 pm
Post Re: 2cv dimensions
thanks
in order...
1260mm
same
2400mm
December 7th, 2009, 10:39 pm
Does the front-rear measurement not change when you lower/raise thee car?
Low and Loud!
December 7th, 2009, 11:00 pm
thanks Sean, and Harry you are right I'm sure, but for the mo thats a good start
cheers
December 7th, 2009, 11:23 pm
As the car loads up, the suspension lowers and the wheelbase does indeed increase. Apparently, with four passengers and their luggage(whatever that means :? )the car's wheelbase increases by 2inches, but the steering geometry also changes, the castor angle increases by 8 degrees, so neutralising any adverse influence the added weight might have on handling and road-holding :shock:
December 7th, 2009, 11:52 pm
Users browsing this forum: No registered users and 94 guests
