| removing old foam from painted metal http://international2cvfriends.com/forum/viewtopic.php?f=7&t=1071 |
Page 1 of 1 |
| Author: | Willami [ November 30th, 2009, 4:54 pm ] |
| Post subject: | removing old foam from painted metal |
any ideas? this is where i have had to remove the sound-deadening trim from the bulkhead and want to clean up the metal.... cheers will |
| Author: | Devils Advocate [ November 30th, 2009, 8:15 pm ] |
| Post subject: | Re: removing old foam from painted metal |
Rotary wire brush - in a drill or angle grinder. |
| Author: | Devils Advocate [ November 30th, 2009, 8:17 pm ] |
(Though you can get solvents to remove the builder's-type expanding foam... Ask at builder's merchants. I don't know if they are similar?) |
| Author: | 2CViking [ December 1st, 2009, 4:49 am ] |
I burn it with a gas flame and scrape it away when soft, easy |
| Author: | bertiewhite [ December 1st, 2009, 1:55 pm ] |
I don't know if this will help, but I've recently had to remove all sorts of foam/sealant/gunk from belinda's window frames and found a mixture of rotary wire brush, solvents & a large screwdriver ground sharp did the trick. It was painstaking though |
| Author: | Willami [ December 1st, 2009, 3:58 pm ] |
thanks bertie, peter and devil will try each one out and report back - shall i read solvent as 'petrol' will |
| Author: | Smiffy [ December 1st, 2009, 4:17 pm ] |
Suggest you use cellulose thinners rather than petrol. No oily residue. Watch out for the fumes though! Too much of them and you'll start making decisions that you may live to regret eg http://www.manolith.com/2009/08/31/15-most-ridiculous-car-mods/ |
