View unanswered posts | View active topics It is currently April 30th, 2026, 3:07 am
Reply to topic  [ 7 posts ]
 removing old foam from painted metal
Post removing old foam from painted metal
any ideas? this is where i have had to remove the sound-deadening trim from the bulkhead and want to clean up the metal....
cheers
will
November 30th, 2009, 4:54 pm
Post Re: removing old foam from painted metal
Rotary wire brush - in a drill or angle grinder.
November 30th, 2009, 8:15 pm
(Though you can get solvents to remove the builder's-type expanding foam... Ask at builder's merchants. I don't know if they are similar?)
November 30th, 2009, 8:17 pm
I burn it with a gas flame and scrape it away when soft, easy
December 1st, 2009, 4:49 am
I don't know if this will help, but I've recently had to remove all sorts of foam/sealant/gunk from belinda's window frames and found a mixture of rotary wire brush, solvents & a large screwdriver ground sharp did the trick. It was painstaking though :cry:
December 1st, 2009, 1:55 pm
thanks bertie, peter and devil
will try each one out and report back - shall i read solvent as 'petrol'
will
December 1st, 2009, 3:58 pm
Suggest you use cellulose thinners rather than petrol. No oily residue. Watch out for the fumes though! Too much of them and you'll start making decisions that you may live to regret eg http://www.manolith.com/2009/08/31/15-most-ridiculous-car-mods/
December 1st, 2009, 4:17 pm
