View unanswered posts | View active topics It is currently June 19th, 2026, 5:27 pm
Reply to topic  [ 87 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
 Electric fan debate
Post Re: Electric fan debate
subarupete wrote:
@Jasu
Removed the oil cooler from the front of engine, used proper oil pipe to bypass
I just took away the original oil-cooler by-pass valve, and put plugs to oil cooler fittings. Small spring was also removed, forgot that when took this photo...
As repair manual said, the by-pass is non-removeable, that isn't true. In real world it is removeable quite easy... :lol:
October 14th, 2014, 3:37 pm
Maybe my description was confusing.
The bypass valve was left in the block.
By "Bypass" I meant.... an oil pipe in place of the oil filter connecting to the input to the output.
See picture the pipe unions are just visible behind the fan.
October 14th, 2014, 4:24 pm
Bigger picture
October 14th, 2014, 4:27 pm
Yes, it can be seen there.
I had once some solution in my "slightly tuned" Visa, with GS gearbox and Visa bellhouse, no oil temp problems even when driven 160 km/h and over...
October 14th, 2014, 4:36 pm
Just a thought but if your forward speed is greater than the fan 'air pull' speed then don't you get increased engine power from the 'windmill' effect..... :lol: :lol:
Conversely if your forward speed is lower, doesn't the fan help 'pull you along', like a propellor. :lol: :D
October 25th, 2014, 3:59 pm
My views on engine driven fans are the faster its running the more air and ultimately cooling you get
October 25th, 2014, 11:09 pm
At the risk of going off on a tangent, some blokes up the road have just posted this youtube video for A$10/GBP5 DIY water-cooling of an intercooler on a turbo'd mx5 that might be adapted for the 2cv oil cooler.
https://www.youtube.com/watch?v=NmzLaaF ... q9Ga8W2J3A
RAID 2016 is underway! See http://www.2cv.com.au/forumdisplay.php/ ... ralia-2016 and just accept the site will always be way out of date because most of the RAID route is nowhere near mobile wifi to give updates.
October 28th, 2014, 2:54 am
Users browsing this forum: No registered users and 236 guests
