View unanswered posts | View active topics It is currently April 29th, 2026, 8:55 am
Reply to topic  [ 103 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11  Next
 my shock absorber just fell of...
Post Re: my shock absorber just fell of...
Miarke wrote:
How will you know who the technical gurus are, if they only share their knowledge by p.m.?
By searching through replies to other questions on the forum, you can decide who you think knows what they are talking about.
Miarke
To be fair, the first line in Roys post says it all;
Roy Eastwood wrote:
~ if one wants just a correct answer with no back & forth chat
It's about choice really isn't it? If you want a straightforward no nonsense answer, ask one person-in this case a tech guru. But, if you want the "banter", ask on a forum.
That's how I read it anyway.
July 15th, 2010, 9:10 pm
i agree with spanners,,
and if you want to hear how people cocked it up in the process public is good !
July 15th, 2010, 11:16 pm
All this shocker shearing bolts sounds like caravan engineering!!!! :lol:
July 16th, 2010, 2:27 am
its a "safety feature" stops too much force being applied to a critical component :lol:
July 16th, 2010, 12:39 pm
Well it would have happened again today, but luckily before work I decided to check my nuts and they were loose on the nearside rear shocker. Tightened them up but I think I'm gonna need to keep checking them!
July 22nd, 2010, 1:36 pm
Maybe a drip of loctite on the threads would help? I appreciate it'll be a twat to remove if it should break, but hopefully it'll stop them dropping out like they are. Also, loctite is easy enough to overcome with a bit of heat anyway.
July 22nd, 2010, 6:32 pm
For what it's worth, my racer uses a Frome racing chassis which also used bolts for the shocks-I've put longer bolts in with nuts on the back of them too.
I don't have any shock absorber dropping off issues. :ugeek:
July 22nd, 2010, 6:36 pm
There's space for me to do that actually, also I'll add some loctite. I want to get the cans offf and actually put some oil in them so I'll get the shocks off at the same time and do that :)
July 23rd, 2010, 2:04 pm
No need to remove the cans, a funnel and a bit of tube will work. Much easier to risk spilling some than removing the cans. If you put a nut on the back then use a nyloc and nont bother with loctite.
July 23rd, 2010, 4:04 pm
July 23rd, 2010, 4:06 pm
