View unanswered posts | View active topics It is currently June 19th, 2026, 9:17 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 71, 72, 73, 74, 75, 76, 77 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
lpgo wrote:
Jameswallace I think Ken is right. Better turn the iddle screw a little inwards that will do the trick.
If it still runs rouhg you can make the maplagfactor smaller. Take a look under the settings tab.. The mapgauge should be around 1 number lets say 22, 23 when on iddle... When mapgauge is going up and down you can make the maplagfactor smaller it smoothens the readings...... Ddid you use the welding tip to let the air pass? It is a sort of restrictor. .6 or .8 mm making the amount of air smaller which can pass and so smoothening the mapnumbers........ Hope you understand..
.6 weld tip...
April 28th, 2014, 10:59 pm
Post Re: 1-2-spark
Received unit all ok, thank you.
Installed the sware all looks good, now need to fit to car, am going to fit it to the 4x4 special as i need a rev limiter...
Need to climb in the back of the car to fit it some where safe...
Peter
May 4th, 2014, 1:54 pm
Post Re: 1-2-spark
Peter
Great, I would put the box somewhere high at the right B pillar or C pillar/3.window, what suits best.. Best is a place where you still can monitor the 2 leds at the box. The yellow led flashes at the rpm of the engine, so you can look if everything is ok....
May 4th, 2014, 6:17 pm
Post Re: 1-2-spark
Have a LNA bellhousing, so i have a great place (x2) for the VR sensor, only need to take the engine out.
Considering putting the 12spark next to coil, lot of vibration, ????
May 7th, 2014, 11:57 am
Post Re: 1-2-spark
My feeling says it is better to put it high up at the body..... for water and for vibration.....
The VR sensor is to short to reach the pickup at the Visa flywheel, I guess you need to work with a bolt or little plate at the flywheel...
p.s. the original pickup of the Visa engine needs to be lined up with the lower hole in the gearbox housing, this is 45 degrees BTDC.....
Can see the Morvan dust all over your engine :lol: :lol:
May 7th, 2014, 12:17 pm
Post Re: 1-2-spark
I went to the French National and gave a little demonstration of 1-2-Spark at the free market at Friday and Saturday. I can only say the responce was overwelming lots of people where very interested and if I had brought some ingnitions with me I could have sold several kits...
My only intension was just to show my ignition and explain the software-hardware to visiters....
So I left with a very good feeling about "the potential" of 1-2-Spark....
I think I need to solder about 10 units asap for people who want one...
Here some pics of the free market....
June 1st, 2014, 7:15 pm
Post Re: 1-2-spark
Do you have any videos of your demonstration? I'd be very interested to see.
June 2nd, 2014, 12:07 am
Post Re: 1-2-spark
Smif, it works like nothing you've ever seen before!
If you need an electronic ignition and are a bit in to tinkering, and computertingies ( to tune it to optimal setting to your car) just order one! You won't regret it!
(No I dont have a relationship with lpgo, neither does he pay me to tell you this guys)
Greetzzzzz
Rusty
bitten by the Citobug...
June 2nd, 2014, 5:49 pm
Post Re: 1-2-spark
Totally agree :) :) :)
June 2nd, 2014, 6:00 pm
Post Re: 1-2-spark
And me - I am getting a new one with a car attached to it :D
Then I am going to ask Ipgo how to programme my current one (which I was going to use on my wife's R4) for my Traction..... ;)
June 2nd, 2014, 6:29 pm
Users browsing this forum: No registered users and 217 guests
