2CV engine with Visa Barrels, heads etc
Roger V
 Re: 2CV engine with Visa Barrels, heads etc
Carb has arrived.  A trial fit at least indicates, it appears to be the correct one.  Choke mechanism is slightly different. But should work. The test will be if the governor connection hooks up. Still a bit stormy out there, so it can wait
| November 2nd, 2023, 3:02 pm |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2257 Location: Near Monmouth
Your the man for Carbs…. EFI etc….
| November 2nd, 2023, 4:00 pm |
Roger V
So, as often happens, when you buy a new broken toy to fix (saves me the trouble of breaking it), you do some research and find the bit you need for it to get it going at minimum cost. Because you don't know if it will work yet, you order the bare minimum. So I only ordered the carb from China. What I didn't order (and now that I think about it, still haven't), is the air box and filter. My rationale, is it would still start and run, and I could see if it would generate sufficient electricty. 've not fitted the carb due to bad weather, but thought I would investigate the airbox a little more. So what do I stumble across!! A duel fuel carb!. £17, and in this country! So I ordered one, just out of interest.
| November 2nd, 2023, 10:30 pm |
AZL57
Chinese carbs They sometimes seem to forget to drill some holes here and there.
| November 2nd, 2023, 11:46 pm |
Roger V
@AZL57 Yes  I'm aware on the short comings of some Chinese products. There again, the engine is a Chinese clone of a Honda. At first I thought the Gen was a somewhat obscure, but reseach over time, suggests it a Honda clone, that has also be re badged a few times. When I discovered it's based on the Honda GX390 engine, but comes out of a Chinese factory as a 188F engine, finding parts was much easier.
| November 3rd, 2023, 9:30 am |
Roger V
I appear to have flared up a Repetitive Strain Injury from years ago, and it doesn't want to heal quickly. So have ordered Electric start kit from Germany.
I may yet need a voltage regulator.
| November 6th, 2023, 12:39 am |
subarupete
Sympathy, suffer from a bad back, does get better, but have to be careful lifting etc
| November 6th, 2023, 12:34 pm |
Roger V
Gen now starts and runs.  Ran better when I connected the governor. Gauge is showing around 240v Need to do some sort of amp test. Still need an air filter box, but waiting on the lpg kit to see what the kit contains. Should be here today.
| November 7th, 2023, 12:49 pm |
Roger V
It boils a kettle
| November 7th, 2023, 3:14 pm |
Ian
Roger V wrote: It boils a kettle  A very important test
| November 7th, 2023, 4:21 pm |
Users browsing this forum: No registered users and 224 guests |
