View unanswered posts | View active topics It is currently May 23rd, 2026, 9:55 pm
Reply to topic  [ 241 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 25  Next
 All about: 2CV suspension
Post Re: All about: 2CV suspension
the usual spanner for this job is pressed out of a 3mm sheet!
carefull of some of the big ones dont fit between the cup and the chassis
another tip is to drill an 8mm hole through the tube and its mount and put a bolt in, this stops the tube turning and lets you back the nut off a bit easier.
sean
September 28th, 2010, 6:53 pm
Jameswallace wrote:
thanks, thats what i wanted to know, i wondered why you needed 8 nuts round the car, all make sense now..
im going to check the state of the nuts and gaiters and endes today to see wehther i need to renew them..
If you read the first page of this thread the reason for needing two spanners is obvious. My 46mm spanner was about a tenner and is a proper bit of kit. As Sean says, a thick end of a spanner won't always fit between the cup for the rubber and the chassis, but that's nothing that five minutes with a grider won't solve.
September 28th, 2010, 7:00 pm
I've got one decent size spanner for leverage, and a shorted GM water pump spanner which is narrow enough to go on the nut and then to wedge against chassis or floor.
September 28th, 2010, 7:03 pm
Is the suspension handed? Found a second hanf can springs etc complete one side
October 3rd, 2010, 9:30 pm
Not handed.
October 3rd, 2010, 9:40 pm
also, ive got the suspension unit ccomplete with 46mm nuts etc all assmebled, as in knife edge to knife edge, do i still need two 46mm spanners??
October 7th, 2010, 11:00 pm
I'd love to watch you try to fit it to the chassis without 'em. Tie-wraps might do the job.
October 7th, 2010, 11:20 pm
ill take that as a yes then :|
October 7th, 2010, 11:35 pm
You really need to read this thread. Start from page one.
October 8th, 2010, 8:21 am
i have, many a time,
i shall read it again :roll:
October 8th, 2010, 9:39 am
