View unanswered posts | View active topics It is currently June 19th, 2026, 3:29 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 67, 68, 69, 70, 71, 72, 73 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Geo, this thread is getting very long! Is there somewhere I can download basic information on the system and how it works?
January 9th, 2014, 11:46 pm
Post Re: 1-2-spark
So i will be sending my chip back to geo for updates, hopefully i can use remote start :-)
Sam just buy it and fit it :-)
January 10th, 2014, 12:04 am
Post Re: 1-2-spark
pmmed you the link to the manual and how to..... How this makes it easier to understand....
January 10th, 2014, 12:32 am
Post Re: 1-2-spark
Quick question just to make things clear
Will the full 1-2-Spark work with original sensor or will I need the optional sensor, or are you testing both to see if both work?
Boggy
January 10th, 2014, 7:04 pm
Post Re: 1-2-spark
Boggy
oke it is getting confusing i know.......
option A: full version with VR sensor (this runs for over 2 years now)
option B: full version for Visa sensor or a replacing sensor (interchangable)... You need to solder 1 solderpad when changing between another type of sensor (first Visa-engine testing this sunday when weather allows)..... both sensors have run at my testbench, so looks very promissing....
option C: simple plug and play version for Visa... (with some dipswitches to set timing right) so no computer needed, but you need the Original wire-loom...
So for you; option B would suite you, if you have working Original Visa/LNA sensors just work with them, you only need 1 sensor with my ignition (in the lower position)...... Because the sensors are only getting stabelised current they will work much longer as normal I guess and if they finally brake down you can Always switch to the replacement sensor......
January 10th, 2014, 7:26 pm
Post Re: 1-2-spark
Yep that works for me
Looking forward to hearing how the testing goes this weekend
Boggy
January 10th, 2014, 8:28 pm
Post Re: 1-2-spark
Tonight I did an engine testrun in my "Ami 6 Service 4x4 tolee".. Didn't run for about 4 years and hasn't been on the road for more the 10 years...... it looks like a barnfind at the moment.....
After some cranking suddenly "THE BEAST" awaked..... running on my ignition and using the replacement sensor in the lower hole...... After some minits it starts running like a dream...
Did some cranking and each time it runs on the first turn of the key, well accually not, I should say at the first pull of the starter :lol: :lol: :lol: :lol: :lol:
I also did a run on the original Visa sensor and it does run on it, but I'm not satisfied yet, it needs some attention... but I think most of us are glad anyway if we can drop the Original sensors :? :?
Well let the video tell it's own story.....
January 14th, 2014, 12:05 am
Post Re: 1-2-spark
http://www.youtube.com/watch?v=Ctin21yrfcA :lol:
January 14th, 2014, 1:01 am
Post Re: 1-2-spark
Thanks Ken; you just made my day (it's 4 minits after midnight over here) :lol: :lol: :lol:
Obvious I didn't bother you all with the half a minite cranking till petrol reached the carb....
January 14th, 2014, 1:07 am
Post Re: 1-2-spark
If I was gonna put a bolt on my flywheel for the sensor, how should it be positioned? at 8° bTDC?
Thanks, Bart
January 25th, 2014, 3:11 pm
Users browsing this forum: No registered users and 206 guests
