View unanswered posts | View active topics It is currently June 19th, 2026, 7:50 am
Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 43  Next
 BMW 2cv engine conversion "2.0"
Post Re: BMW 2cv engine conversion
Did the bmw exhaust have a balance pipe?
New pipes look tidy, are they SSteel?
May 6th, 2014, 8:32 pm
Depends on the model, I think most are 2 into 1.
May 6th, 2014, 10:32 pm
All Beamers are 2 in 1 at the end (of the exhaust)... 1100,1150 1200 got balancepipe,
This is from the 1200 GS look at the 2 bungs for the lambda probes, theyve done everything to make it superfuelefficient, sequential injection aso.
normally they say a balancepipe gives you more midrange torq..... but do I need that, I think it will bring me and the gearbox in even more trouble.....
my exhaust is "stoombuis" translated its steamtube it is about 3mm wall-thick... so should do the trick....
May 6th, 2014, 11:51 pm
Cheapest\Best wideband lambda controller on the market, with integrated micro controller.
Makes multiple sensor use very cost effective!
I'm using one ;-)
http://www.14point7.com/products/spartan-lambda-sensor
Harley
May 7th, 2014, 10:10 am
I'm using one ;-)
Harley
I have used 14.7 in my Turbocar.... Didn.t like it then (5 years ago), maybee they are better now.. I use now techedge.... made in Australia :lol: :lol:
May 7th, 2014, 12:21 pm
do you already have the adapterplate made? otherwise you can stop by here [ close to eindhoven] and we can see if i can make it for a nice price. got the tools / machine's for it haha. and a good friend with a huge watercutter.
for all your custom parts : https://www.facebook.com/JoeyBrinkmannCustoms
May 10th, 2014, 9:00 pm
Thanks for your offer..... may be I will come back to it......
I'm thinking to make the adaptor plate out of 6mm steel, with 30*3mm strip as a seam running along the outerline giving massing strenght to it.......
6mm steel I can do with my jig-saw, then I can also weld the engine-mounts directly to it....
Then making many holes in it to lighten it up.....
Got several parts to make it happen....
Electric petrolpump, powered by 1-2-Spark. It will run for 8 seconds when the ignition is turned on or ofcourse when the engine rotates....
Oilcooler, from a automatic gearbox from Ford pickup..... Still to small I guess, probably I will put it again in the right front fender like my turbocar....
Flywheel bolts M11*1.5..... Have got four but I need 5 arghhhh....
Won also a right valvecover on Ebay, this part was what I still was missing.. It is full of scratches, so no Motorcyclist wants it on his/her bike, so an opportunity for us 2cv drivers....
My plan is to make the engine run without flywheel, just to look if it runs.
hopefully it runs so I can order the flywheel spacer(s) and make the adaptorplate.....
May 10th, 2014, 10:39 pm
ok. the pics of the day.
First the exhaust, did a little comparing to a standard 2cv... watch out for the echo, echo, cho, ho, o :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Ok, so if anybody dear to say this is ridiculous he's got a problem with me....
THIS IS RIDICULOUS...... but I like it...... a lot...... 8-) 8-) 8-) 8-) 8-) 8-) 8-) 8-)
ALso did some wishfull thinking, an Original Beamer has got a catholic? converter, I have a very free flow exhaust so should give me some extra horsepower...
Try to shape the fenders, but because I channeled the car I miss just these 7cm.. On a standard 2cv it would fit perfectly, but no it has to be a channeled car.... sh*t....
May 14th, 2014, 10:16 pm
"Catholic converter" thasts something you dont see on your average car!
catalytic converter
:lol: ;)
May 14th, 2014, 10:30 pm
I like my "Catholic converter"
May 14th, 2014, 10:41 pm
