View unanswered posts | View active topics It is currently April 28th, 2026, 1:47 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 46, 47, 48, 49, 50, 51, 52 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Ok so i connected laptop
Crashed latop. Good start
After laptop had hissy fit all was ok
Laptop wont connect to wifi anymore. Who knows why!!
Anyway so i had a play with the advance. This is what my table looks like at the moment
Mark, can you send me your table to look at? It was dark when i did this so
Maybe i will have another play monday after work
Edit
Forgot to add i re connected te vacumn tube and adjusted the advance so it ran smooth on idle, and smooth at about 1500 rpm (previously lumpy)
July 7th, 2013, 12:09 am
Post Re: 1-2-spark
Jameswallace I modified your table (look below). As you can see the table jumps from 25 to 15 when iddling thats why it runs rough. Change it also to 25 degrees (double click at the cell the number will turn blue and you can adjust it... By clicking at enter you will save it to the controller) thats it...
First row has to be 4 degrees (as told before for crankspeeds) so change the 6 into 4.
At the yellow circle the numbers are incorrect too... I will send you my table for that..later this day
You can simply import my table into the controller, click the import button, search the table at your computer, open it there will be a pop up when the table is ready at your screen, then
an "burn button will appear" just hit it and you will see it will send the data to the controller
(you can see cell by cell which one is burned at the moment) 8-) 8-) 8-)
You mentioned Mark (4x4) I guess to send his table but thats to low for your engine, ut fel free to try it.....
p.s. you can change the table 100.000 times before the chip starts to give up (garanteed by the chip company) so you can burn a few tables :D :D :D :D :D :D :D
July 7th, 2013, 11:25 am
Post Re: 1-2-spark
Geo changed it from 25 to 15 and it ran better after doing that on idle. I did play a bit and thats how i have it at the moment
Ill change te ones in the yellow circle once you sed more info
July 7th, 2013, 3:06 pm
Post Re: 1-2-spark
Today was/is a beatyfull day here in Holland so I had to take advantige of that, anyway heres the table I'm driving on at the moment.....
or as table (download and unzip it) import it into the software and burn it to the controller....
table 1 7-7-2013.zip
P.s you can open it als with excel or even wit notepad or similar..
July 7th, 2013, 8:50 pm
Post Re: 1-2-spark
Thanks geo
I will dowload and try that
When i had the bottom box 3 from left at what you did it ran v rough with pipe connected on idle
July 7th, 2013, 10:25 pm
Post Re: 1-2-spark
Edit
I set up an old laptop to run 1-2-spark and it crashed first time I connected it up. I think it had something to do with the USB to RS232 cable.
I'll take some shots of my setups tomorrow and post then here.
July 8th, 2013, 9:54 am
Post Re: 1-2-spark
Today i uploaded geo's table
Car ran rough on idle again so put it back to 15 and it ran fine !!!
I dont know if it pinks because ive never heard pinking knowingly before... So need to learn what exactly it sounds lik!!
Ill show a picture later of my table
July 9th, 2013, 6:59 pm
Post Re: 1-2-spark
I was going to suggest vjaning it back.
July 9th, 2013, 7:05 pm
Post Re: 1-2-spark
Didn't Geo advise against vjaning it back? I think you'd be better off kdupputising it forwards.
July 9th, 2013, 7:13 pm
Post Re: 1-2-spark
I don't mean any offend anyone here as this is obviously a very clever device that I'm sure will have it's uses but it seems to me to be a bit overly complicated for a 2cv that is used in normal conditions. I have a modern car and the first thing any mechanic or AA man :( does is plug a laptop into it but this doesn't seem right for a 2cv somehow. If it's broken I just want to mend it with a hammer and a spanner not fire up the laptop.
Just my two pennies worth.
July 9th, 2013, 7:24 pm
Users browsing this forum: No registered users and 132 guests
