View unanswered posts | View active topics It is currently April 28th, 2026, 1:05 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 44, 45, 46, 47, 48, 49, 50 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
djjr1982 wrote:
Somebody is making big profit!!!!!!!!!!!!!!!!!!!!!! :shock: :shock:
June 20th, 2013, 5:33 pm
Post Re: 1-2-spark
Been busy so used truck lately. But started the car yesterday, fired instantly :)
June 26th, 2013, 8:54 am
Post Re: 1-2-spark
James, if you haven't made the vacuumconnection yet, heres a very simple way to do it,
drill a hole 4mm into the inletmanifold (for instance in the tube near the sensor holder), tapper m5 into the tube. put in the welding tip with your silicon stuff (or loctite) and thats it. Every place at the inletmanifold would be great, theres the same vacuum through the whole inletmanifold....
So no drilling tapping at the carburator wahsplate, no drilling tapping in the carburetor....
just easy going 2mm tube to drill and tap..... :idea: :idea: :idea: :idea: :idea: :idea:
p.s. did you try to tune it already???
June 26th, 2013, 10:10 pm
Post Re: 1-2-spark
Will do that geo thanks. Oh but what about filings into the manifold?
Not yet, very busy with work will be doing a 33shift tomorow :roll: but i will dont worry
Is there a tuning guide in the files you send me?
June 26th, 2013, 11:34 pm
Post Re: 1-2-spark
Hi lpgo
What about these to replace the Visa sensors
http://www.ebay.co.uk/itm/190838209956? ... 1423.l2649
and
http://www.ebay.co.uk/itm/221241432666? ... 1423.l2649
let me know what you think
Boggy
June 28th, 2013, 9:46 pm
Post Re: 1-2-spark
I have bought these some time ago....
http://nl.mouser.com/ProductDetail/Cher ... NQ8w%3d%3d
The problem is these go from 12 volt to 0 volt (when the pickup arrives)
The original Visa sensor goes from 12 volt to 6.3 volt (when the pickup arrives)
Now the amplefyer I use works only when there are - volts involved. The Vr sensor
goes from +250volt to -250 volt at 6000 rpm and at each zero-crossing there goes a signal to the chip that the sensor has passed.....
Now with the sensors above theres never a zero crossing so it wont work yet.......
What I'm now trying to do is to say to the amplefijer that 5 volt is the crossing point, I hope this will work, then the problem is solved for (the Cherry sensor) Hall sensors....
So I'm working on it.....
June 28th, 2013, 10:23 pm
Post Re: 1-2-spark
Ok good luck, so looking forward to having this engine running on 1-2 spark
Boggy
June 29th, 2013, 10:03 am
Post Re: 1-2-spark
@ Harley, if you can send me 2 truck coils that would be great, I will make it happen and send them and the working unit back to you....
I only have 4 but will post them to you as I don't need them yet! Then you can let me know by seat-of-your-pants tuning if they make a difference. ..
Please pm or email me your mail address.
Harley
June 30th, 2013, 2:49 pm
Post Re: 1-2-spark
@ HARLEY
p.m.ed you my adress.....
Can't wait to see if 1-2-spark can fire coil on cop.... which is the same as your
LS1 coils...... Theoreticly it must work...
b.t.w. I've send a unit to Germany, this unit is going to do twinspark but with 2 standard 2cv coils...
1 coil is doing the upper plugs the other coil is doing the the bottom plugs :roll: :roll: :lol: :lol:
should be arriving these days at germany.......
When this works I want to do twinspark myself, should give a little more power and even less fuel...
July 1st, 2013, 12:29 pm
Post Re: 1-2-spark
Today i had a flat battery on 2cv. Not completly flat but only just enough to turn over. It fired up none the less instantly. Amazed!
Ive adjusted the idle so it runs better
Sunday ill take the car to work and after work i will fit the vacumn pipe and also going to make holein where the wires pass through bigger. Im also going to fit a piece of 13mm water hose over the wires to protect them. While i do this im going to also move the black box as currently its under the left hand heat pipe for the feet so im geussing it may be getting a bit warm..!
I will photo where ive fitted 1-2 etc
Running really well :) top product geo!
July 3rd, 2013, 7:43 pm
