View unanswered posts | View active topics It is currently April 27th, 2026, 11:19 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 39, 40, 41, 42, 43, 44, 45 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Planned to fit 1-2 spark to the 2cv yesterday but didnt forany reasons
In order to get to te 2cv it meant a 1.3mile cycle ride
So i loaded a freshly charged battery into the basket of mums bike,y spare flywheel to practice on in the pania along with my lunch
Cycled to my truck, wound rear window down to get tools, loaded tools in the basket, window wouldnt wind back up. Un loaded push bike, an had to take truck to work. Window wound up fine after 10 mins driving
Doh.
1-2 to come next week!!
June 14th, 2013, 6:50 pm
Post Re: 1-2-spark
Can't wait.... :D
June 14th, 2013, 8:38 pm
Post Re: 1-2-spark does TWINSPARK
1-2-Spark does twinspark..... 8-) 8-) 8-) 8-) 8-)
Couldn't wait had to test it this evening.....
Took 2 2cv coils and put them in my 2cv.
1 coil to the left plug and the other coil to the right plug.
The 2 other leads to my aloy testplate with also 2 plugs...
Heres a drawing of it
So guess what......... it runs very well
Heres the video of today....
https://www.youtube.com/watch?v=914TS6Wy2EA
So now you can run:
1 2cv coil 2 plugs
2 coils 1 plug each
2 2cv coils twinspark
4 coils coil on cop
all in wasted spark (at the moment) I'm running out of memory again so I don't know if sequential is possible........
June 14th, 2013, 11:01 pm
Post Re: 1-2-spark
Can't wait.... :D
Provided i can have a cockup free day itll o in thursday!!
June 14th, 2013, 11:09 pm
Post Re: 1-2-spark
lpgo wrote:
@djjr1982 leading edge is inderdaad de voorkant (de kant die het eerste bij de sensor is deze moer recht zijn achterkant maakt niets uit....
@Chris and djjr and all other 1-2-spark drivers... Theres going to be a 1-2-spark dynoday at 18 october 2013, time from 10.am till.....
so please contact me if you want to join. It will be around 75 euro for a car (about 1 hour run) maybee less, strapping it up takes about 15 minits.... so theoreticly 3/4 of an hour tuning
It is held here.... http://www.tuningfactory.nl/
I be there
2cv6,5
June 15th, 2013, 12:11 am
Post Re: 1-2-spark
You legend Geo!
I think I need to send you some Ls1 coils to test the 1-2-spark with.... what do you think?
I'll check out euro eBay or send you the ones I already have, that way it can be tested for sure.
Nice work.
Harley
June 15th, 2013, 8:50 pm
Post Re: 1-2-spark
Harley wrote:
You legend Geo!
Nice work.
Harley
I'm pretty sure it will work... but I found this here in Holland....
http://www.jfetech.nl/epages/080402.sf/en_GB/?ObjectPath=/Shops/080402/Products/LS2-Coil%2BConn
Is it a good price????
June 15th, 2013, 11:06 pm
Post Re: 1-2-spark
I fit a new pickup with 1 bold.
I use Locktite to secure the bold.
Ignition is running well now.
2cv6,5
June 15th, 2013, 11:20 pm
Post Re: 1-2-spark
Did you drill and simy tap?
How come the leadig edge is folded up ?
June 16th, 2013, 5:16 pm
Post Re: 1-2-spark
i drill a hole 2,5mm then i cut screw-thread M3. The bold is a normal hex bold. Not recessed i have used locktide and a lock washer.
What do you mean with folded up? The pickup is not perfect square but not folded up.
The pickup is 1.5mm thick and is to stif to bend or somthing.
I have round up the corners a little.
Now i know it works great i go balans the flywheel. I calculate it need to holes 4mm wide and 2cm deep.
2cv6,5
June 16th, 2013, 10:06 pm
