View unanswered posts | View active topics It is currently June 19th, 2026, 10:33 pm
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Front Wheel Bearing
Post Re: Front Wheel Bearing
S ill check that
K thanks, i never overtighten wheels... Will check both
But seems that thr bearing moves inside the hub but could be the hubs not on all the way
May 5th, 2014, 10:08 pm
The wheel bearing has a two-part inner race, which needs to be clamped tightly together by the driveshaft nut.
An average person standing on a 3/4" drive breaker bar at 450mm to 500mm radius should do the job...
Jameswallace wrote:
S ill check that
May 5th, 2014, 11:18 pm
Going to look at this sunday, or tomorow
May 8th, 2014, 9:42 pm
"whichever comes first" :lol:
May 8th, 2014, 10:10 pm
:lol:
I wrote that, and realised my error but thought fuck it
I actually went out just now and stripped either the thread on the driveshaft, or the nut by jumping on thr breaker bar
Next is matches
Got the arm off the car and am going to ask daras to sort it i give up
May 8th, 2014, 11:41 pm
I was in the process of replacing a front bearing until reading this account of James. I'm re-building my 2cv and I'm cleaning/overhauling/re-newing parts as I go.
I soaked one of the front hubs in parafin to clean it of all the accumulated, encrusted grease. I have a new bearing and seals so I thought I'd replace the old one as the parafin would have degraded the bearing's grease.
I wish I had read this first as I would have taken more care on cleaning without soaking :(
However, having removed the wheel flange and the seals (ring nut not touched) the bearing inside is in two halves, unlike the replacement one, and is able to move back and forth (incidentally leaving room between the two halves to re-pack with grease) What is confusing though, because of this ability to move, the ring nut is not acting on it at all.
So, does the ring nut only come into play when the wheel flange is re-installed?
On inspection of the other hub (fortunately not soaked in parafin) it's bearing is also in two halves. I was under the impression that front and rear wheel bearings were interchangeable. The bearing I have was originally acquired for the rear. (But is one piece)
Any comments gratefully received. Thanks
Steve
June 20th, 2014, 11:58 pm
Front and rear bearings are interchangeable, but construction differs depending on the make.
The ring nut bears on the outer race of the bearing and this should not be able to move. The two half's of the inner race are loose until the wheel flange(usually called the hub) and the driveshaft are assembled, these then clamp them together.
June 21st, 2014, 2:21 am
Thanks Joolz. I know it's not rocket science but when the bits/procedures you have/carry out, don't fall into the descriptions of other people (or the Haynes manual) you start to doubt yourself!
This is where this forum is great.
Thanks again.
Steve
June 21st, 2014, 8:43 am
Users browsing this forum: No registered users and 217 guests
