samfieldhouse
 Re: Misfiring & backfiring
160psi per side when last I tested, there's plenty of umph... wen it's working!
On the other hand I know the rings on IT are worn...
Where did you get your M4 rings Dave?
| April 10th, 2013, 8:53 pm |
J-dub
Russell wrote: IT, not HER FFS. Sorry sam. But +1
| April 10th, 2013, 9:00 pm |
Nelsthebass
If its only dribbling doesn't sound right - needs to be a nice atomised spray so suspect something is either blocking the flow to the jet or has the accelerator pump diaphragm split?
| April 10th, 2013, 9:18 pm |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
Sam,they came with the pistons i bought from Ecas. The reason I suggested a compression test was to check that an inlet valve wasnt on its way out.Worn rings wouldnt make it fluff through the carb.If you do have a semi blocked jet,it will run lean and backfire/fluff/fart/what ever through the carb.But,it could also be the coil or condenser.If you are going to fit a new condenser,mount it near the coil and extend the wire.Makes it easy to change next time.
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| April 10th, 2013, 9:41 pm |
ayjay
Nelsthebass wrote: If its only dribbling doesn't sound right - needs to be a nice atomised spray so suspect something is either blocking the flow to the jet or has the accelerator pump diaphragm split? exactly i bet the diaphram is split if the accelerator pumps knackered/ nozzel blocked they don,t run properly and spit back thro the carb
| April 10th, 2013, 9:53 pm |
Russell
Accelerator pump diaphragm wouldn't cause it to pop and bang and limp along, it'd just take bastard ages to get to top speed where it'd run fine, wouldn't it? That's how split accelerator pump diaphragms have made my cars behave. I think this is more down to points, condensor or coil. I don't understand how a blocked jet or split accelerator pump will make it backfire through the carb.
But I don't know anything really, could be a jellyfish in the exhaust for all my knowledge is worth.
| April 10th, 2013, 10:01 pm |
Macabry
Joined: April 18th, 2010, 11:48 pm Posts: 205 Location: Newent, Glos.
Nah...if it was a jellyfish there'd be more backfire, popping suggests its a mackerel problem...
_________________ '87 2CV Special,'78 AMI 8,'52 Anglia, '71 Capri 3000E, '67 Ford Fairlane 500 V8, '69 Ford Torino V8,'99 Xsara,'28 Ford Model A Tudor, '82 G Wagon, '68 LWB SII Landy and some manky renault Meganes.....also Ukranian KMZ MB750, Suzuki TS100,Mobylette.
| April 10th, 2013, 10:30 pm |
ayjay
check it anyway, that was the same as brothers prob, operate the throttle arm whilst looking down the carb there should be a fine squirt of fuel emmitting from the tip of little brass tube that hangs above the butterfly
| April 10th, 2013, 11:17 pm |
ayjay
Russell wrote: Accelerator pump diaphragm wouldn't cause it to pop and bang and limp along, it'd just take bastard ages to get to top speed where it'd run fine, wouldn't it? That's how split accelerator pump diaphragms have made my cars behave. I think this is more down to points, condensor or coil. I don't understand how a blocked jet or split accelerator pump will make it backfire through the carb.
But I don't know anything really, could be a jellyfish in the exhaust for all my knowledge is worth. def did on brothers ak
| April 10th, 2013, 11:18 pm |
J-dub
Basicslly check / clean everything
| April 11th, 2013, 12:21 am |
Users browsing this forum: No registered users and 235 guests |
