View unanswered posts | View active topics It is currently May 2nd, 2026, 7:35 am
Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 11  Next
 B7 plugs?
Post Re: B7 plugs?
Thank ken I'll order one today :D
September 22nd, 2011, 10:14 am
Post Re: B7 plugs?
Does that decrease economy?
September 22nd, 2011, 1:07 pm
Post Re: B7 plugs?
I assume the transition from first to second choke is about half throttle? Mine seems a bit hesitant sometimes but never thought anything of it. The dyane carb has a 107 jet I think. No idea what my 2cv carb has
September 22nd, 2011, 3:18 pm
Post Re: B7 plugs?
Can't be sure as I haven't received the bigger jet yet but to overcome the hesitation at low throttle openings I've been flooring the throttle most of the time and guess this must drink excessive fuel. We'll see ;)
September 22nd, 2011, 3:27 pm
Post Re: B7 plugs?
Stupid question alert
Sam said My car drove nicely but was hesitant and reluctant at low speed in 2nd, would a bigger jet make any difference to that or is it the nature of my car?
September 22nd, 2011, 3:32 pm
Post Re: B7 plugs?
Mine too. And in 3rd and top. We'll see what difference the new bigger jet makes. Hopefully it will be here tomorrow.
September 22nd, 2011, 3:40 pm
Post Re: B7 plugs?
Where did you order it from and whats the part number please??
Regards Pat
September 22nd, 2011, 4:05 pm
Post Re: B7 plugs?
http://www.ecas2cvparts.co.uk/primary-v ... -1454.html
September 22nd, 2011, 4:15 pm
Post Re: B7 plugs?
http://www.ecas2cvparts.co.uk/primary-venturi-petrol-metering-1826-2635-carb-size-increase-most-popular-size-p-1454.html
This a standard jet or do I need to check what type of carb is fitted??
September 22nd, 2011, 4:37 pm
Post Re: B7 plugs?
Not noticeably,
as the improvement in power on the first choke when it's no longer running lean means that you'll probably use a smaller throttle opening to travel at the same cruising speed.
A mixture which is too lean burns slower than one which is correct and may even be still burning when the exhaust valve opens.
September 22nd, 2011, 4:56 pm
Users browsing this forum: No registered users and 118 guests
