View unanswered posts | View active topics It is currently May 1st, 2026, 12:11 pm
Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Spare wheel or not?
Post Re: Spare wheel or not?
personal opinion i geuss!
i think it sunk down in the bonnet a bit looks cool,
does it not block your view at all?
September 8th, 2010, 3:34 pm
I found that when I had a spare wheel on the bonnet the washer was a bit useless as when driving what came out was blown all over the place by the turbulence caused by the wheel. Still I had no issues driving with a grubby windscreen...
September 8th, 2010, 3:41 pm
Rhythm Thief wrote:
Jameswallace wrote:
thats very cool. what about something like the sahara has? similar but sunk into the bonnet a bit?
That's easy enough to do as well,
Lots of people have tried to copy the Sahara bonnet and few have succeeded in making a good job. though I have seen a few. It also makes your already flimsy bonnet very heavy and very wobbly when open on its thin little bonnet prop.
September 8th, 2010, 3:59 pm
Beefing up the prop is easy enough to do though.
September 8th, 2010, 4:27 pm
and beef up the rest of the bonnet also? if sahara bonnet can cope surely the standard can be modified to cope in a similar way??
September 8th, 2010, 4:58 pm
Not so. The original "ripple bonnet" is a much stronger unit to begin with, has side bits and is made from steel not biscuit tin.
September 8th, 2010, 5:02 pm
fair enough, didnt know that it was more robust, or get an old ripple bonnet and make it fit and work?
only an idea :lol:
September 8th, 2010, 5:06 pm
I beefed up my bonnet by bolting two lengths of dexion across the bonnet under the spare wheel. It wasn't an elegantly engineered solution, but it worked. :)
September 8th, 2010, 6:19 pm
Most of the spare bonnets I've had that have been useless were so because the hinge had come away due to fatigue, the spare mounted upon it will surely accelerate this?
September 8th, 2010, 6:40 pm
unless you make some sort of slightly more sturdy version up and beef it all up, maybe even proper hinges?
September 8th, 2010, 7:51 pm
