View unanswered posts | View active topics It is currently June 20th, 2026, 12:15 am
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 33, 34, 35, 36, 37, 38, 39 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
I'm bloody amazed at how fast you have implemented multi spark from it's conception. Well done !
March 31st, 2013, 2:07 pm
Post Re: 1-2-spark
I have reprogrammed the timing section copple of weeks agoo, now I have the benefits of it,
implementing new programming code, goes very fast and easy.........
There are 3 to do things on my list......
real time barometer correction...... (making a correction going up and down mountains)
implementing a oiltemperature sensor (about 12 degrees boxes -40-150C and where you can % give more or less advance
changing map and rpm range like you want it to be......
But first I will make the software work so that you can fiddle with the multispark numbers..
March 31st, 2013, 2:59 pm
Post Re: 1-2-spark
Looks like there is going to be a 1-2 spark version 3 soon....... When are you going to stop!!!!!
March 31st, 2013, 3:26 pm
Post Re: 1-2-spark
Injection!!!!
March 31st, 2013, 5:43 pm
Post Re: 1-2-spark
Of course we want that too! :) i've been thinking about injection, for monopoint you already have 1 signal, but for multipoint (what I want) you need 2 signals to know what cilinder has to inject. Is it possible to make 1 sensor on the back of the flywheel (like visaengine) and 1 on the front (like you have now) will that be enough? Or is there more to it?
Greetzzzzzz
Edit:
Starts to look like megasquirt if you keep adding things like this :mrgreen:
bitten by the Citobug...
April 1st, 2013, 10:44 am
Post Re: 1-2-spark
Harley, heres a topic for you, twin spark, coil on cop its even a air-cooled engine....
When I was reading al this I was thinking you are right all the way.....
http://rennsportsystems.com/letstalk-2/gasoline-detonation-twin-ignition/
April 10th, 2013, 6:30 pm
Post Re: 1-2-spark
Nice find LPGO,
I've been thinking... would it be ok to fire all 4 COP at yhe same time in a wasted spark configuration.
Or, would I need to use a single 4 tower wasted spark coil, like found on V8 wasted spark setups., or alternatively, 2 2cv coils...
Thoughts?
Harley
April 11th, 2013, 5:57 am
Post Re: 1-2-spark
Harley wrote:
Nice find LPGO,
Thoughts?
Harley
Do as I told you.......
1.) try 1 2cv coil use original sparkplug left and right
then use the new sparkplugs and see if it happily fires on them too.
2.) try 2 2cv coils 1 for left cilinder, 1 for right cilinder firing 2 sparkplugs each.
3.) try coil on cop first 2 original sparkplugs then 4 sparkplugs....
ps.1. I will make you 2 ignition drivers so you can use 2 2cv coils.....
ps.2 Be carefull with the ls coils, you must take the leads directly from the chip then, so 1 time incorrect connection and the chip will be gone........
New chip will cost about 10 euro + P and P.
As far as I can read in Megasquirt you can take the dwell from 1-2-spark to load the ls coils so it should work!!!
ps.3 At the moment I can only deliver wasted spark, but I'm very coinfident there will be no problem with that. Otherwise I will programm a second VR sensor on Cam and will programm sequential ignition as described some pages ago.. (but you then said youve got a Megasquirt so I left it).......
I think Saturday I will post all the components to solder 10 units profesional, so I hope within a month I can start to deliver.....
I had the first Mark II (with mapsensor) delivered to ChrisW. for his turbocar, but he had issues with advance retarding under boost (I had a little bug in the software), but I have solved this problem.... (I hope)
I myself have problems overdoing advance under low load, I think I'm going to order colder plugs, preventing pre-ignition and see if that helps.....
Otherwise I need to implement a tempsensor, retarding ignition when the engine is hot.... 1-2-Spark Mark III.......
April 11th, 2013, 12:35 pm
Post Re: 1-2-spark
:) will you ever be satisfied?
keep on going!
April 11th, 2013, 1:22 pm
Post Re: 1-2-spark
I'd like a bolt on injection kit.
April 11th, 2013, 8:09 pm
Users browsing this forum: No registered users and 221 guests
