View unanswered posts | View active topics It is currently June 19th, 2026, 12:36 am
Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Crankcase breather/Reniflard is it duff?
Post Re: Crankcase breather/Reniflard is it duff?
Grind round the joint, just enough to remove the fold, each half SHOULD have a shoulder.
I had some alu rings laser cut, that when bolted up, pull the two halves together, the two rings one complete others one in two parts... if memory is working....ABS should work for the rings, minimal loading...
April 9th, 2021, 4:51 pm
So Pete ...
Do you have any reed material left?
Are you intending to start a new one, or try this on the one you have already converted?
April 9th, 2021, 7:43 pm
Material ————— yes
Another ————— yes
Waiting ABS parts - yes
April 9th, 2021, 8:32 pm
I guess your sorted for a clamp .....
April 9th, 2021, 8:47 pm
Clamp —- no I gave all the bits away in Belgium.
Try to cost the parts, may be sell on the forum,
April 10th, 2021, 9:28 am
Just on a fuel injection site and had a thought! ..... that's 2 already this year!
My engine management cpu has a MAP sensor. It would be interesting to read the crank case vacuum.
If I recall, its usually read from the dip stick hole, is that right?
what would be good readings?
April 10th, 2021, 11:59 am
Built a manometer using LHM fluid..
See here https://shared.yellowgrey.com/2016/08/2 ... manometer/
April 10th, 2021, 5:46 pm
Yeah .... I know ..... but ..... everyone does that. And, it's not so easy to get wrong as what I want to do ..... :lol: :lol: :lol:
April 10th, 2021, 5:58 pm
The crankcase vacuum is minimal, need a sensitive unit ....BMP 180 I2C mounted in an air tight box?.....
April 10th, 2021, 6:13 pm
How much lift do you think the reeds need? How much would the rubber ring have given?
April 11th, 2021, 12:53 pm
