View unanswered posts | View active topics It is currently June 19th, 2026, 10:32 pm
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Front Wheel Bearing
Post Re: Front Wheel Bearing
More f'ing problems
Bearings in now for retaining nut.... V start to thread is a tad damaged in places........ I may be able to rescue with a needle file but is there any other magic tricks ..? This is boring now
Everytime intouch it i fuck it up
May 4th, 2014, 8:46 pm
Keep calm and try to obtain a thread file, freshen up the threads and try again.
May 4th, 2014, 9:43 pm
Thats a cracking idea. I never knew there was such a thing as a thread file....!
May 4th, 2014, 10:24 pm
Jameswallace wrote:
More f'ing problems
We all suffer from it at some stage...
Harley
May 5th, 2014, 11:06 am
metric thread is 60* so a triangular file fits and cuts the correct profile. if its the internal thread in the housing "rake" it with a tap of the same pitch if you gety it just right it will cut the burrs.
May 5th, 2014, 2:36 pm
Thanks managed it with lots of time and a needle file
So nut does up (took maybe 5 hours to get it on) and goes v tight (flush with the arm) but theres a small amount of movement in the hub (which is in the bearing) which is in and out
Ive not missed anything, but it just seems rediculous and stupid, what have i done (apart from made the mistake of doing this myself....)
May 5th, 2014, 6:40 pm
yes the hub nut! you need the C_V joint and the nut done up tight to clamp it up or the bearing centre is loose.
May 5th, 2014, 8:51 pm
All done up tight (inc hubnut) and the wheel flaps about all over the place
Did both up with breaker bar ......
May 5th, 2014, 8:52 pm
has the centre hub seated properly youve not mangled anything with the crowbar and hammer?
May 5th, 2014, 9:38 pm
James,
the driveshaft nut needs to be tightened to much the same torque as the bearing retaining nut, around 250 lb.ft./35 kg.m with greased threads.
Don't overtighten the wheel nuts or you will ruin them; 30 lb.ft./ 4 kg.m is enough...
May 5th, 2014, 9:51 pm
Users browsing this forum: No registered users and 223 guests
