View unanswered posts | View active topics It is currently June 19th, 2026, 6:10 pm
Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4
 Towing a 2CV
Post Re: Towing a 2CV
I was towed by the AA using this method once, the only trouble was their A-frame didn't have a bend in it so it banged on the bumper going over bumps. I quite like it as a method of towing.
March 21st, 2013, 1:20 pm
As I've already posted I've a friend in our village who has just returned from UK towing his 'A' series that has an extended chassis due to the GS engine,plus a replacement Peugeot 206 engine in the back of the towed car,all on an A frame with no problems.He has towed another f is 2cv's with a 2cv back from UK to SW France also without incident. I would suggest that ensuring your fixation points are done tight and correct.I to would like to know about near accidents :-)
March 21st, 2013, 1:59 pm
Online
Have used a "2cvcity" strap-on A frame on many years/occasions/miles, with no issues.
However ....have lent it out a number of times.
1. Downhill on a very tight hairpin in Langdale, The towed car tried to steer the rear end of the towing car.
A very near miss.
2. After many kms in France I think the tow hitch bolts on the frame became loose.
A very near miss.
Just be very careful with ..... tight bends.....roundabouts and downhill.
ps I think its be said before ---- Check you driving licence and insurance.
March 21st, 2013, 5:07 pm
I can only confirm I use such a tool as well.....
Don't tow another 2cv with a 2cv, they are to light when braking hard the towed car will push the towing 2cv (In my case an AMI 8 service) aside.... My ami made a 180 degrees turn and damaged 2cv frontwing and amiservice rearwing.
Don't drive backwards (you can't anyway) the sterringwheel shares to 1 side at once blocking everything.
Don't make small turnes, when the towed car hits the steering stop and you will still make a nearower turn disaster will strike.... Both cars will get into a woble the only thing which helps is to stop and go....
b.t.w. in Holland it is allowed when both cars have MOT and Insurance......
March 21st, 2013, 6:56 pm
Hire a trailer. It seems like a lot less bother.
March 21st, 2013, 7:18 pm
ipgo,
this highlights another example of the twisted logic often used by our pen-pushers. :roll:
In the UK, the weight of the vehicle being towed is deemed to be its Gross vehicle weight, not its kerb weight.
That makes a towed 2CV 930kg, instead of 585kg.
You've got to wonder just how likely it is that someone is going to tow a car with 4 people on board, plus their luggage.
March 21st, 2013, 7:44 pm
ipgo,
Bit like every young persom cant tow an empty brakes trailer
March 21st, 2013, 8:47 pm
Heres my towing device, it can hinge just before the towed car I've made it 25 years ago
it did many jobs...
May 19th, 2013, 12:00 am
