Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Headlamp relays for halogen bulbs
Post Re: Headlamp relays for halogen bulbs
James,
one of these will do the job.
< http://cgi.ebay.co.uk/NEW-Circuit-Teste ... 1152wt_704 >
Btw, watch out for the sharp end when you're using it to find which wire needs to be cut... ;)
Jameswallace wrote:
relays are arriving at the end of the week, so im going to be fitting them, where do you suggest i wire them in, near the battery, or at the headlamp bar end?
if i do it at the battery end, which wires is it, as theres millions to choose from adn i dont want to be cutting and re conncetiong 10 wires before i find the right one, (unless there is no other way?)
October 5th, 2010, 11:52 pm
how does it split then, is it an obvious split when it goes of to the seperate lamps? ie bullet connectors or alike
ahh i think i have one of those somewhere ken, not sure where though, will my multi meter be ok for the job in hand though?
October 5th, 2010, 11:54 pm
It's obvious once you've unwrapped the loom, no connectors it's a permanent join, crimped together with a piece of brass probably.
October 5th, 2010, 11:58 pm
ok thanks, what i needed to know :)
October 6th, 2010, 12:01 am
Jameswallace wrote:
toomany2cvs wrote:
Old-Nail wrote:
If I fit the halogens without relays for the time being am I risking armageddon or no?
Possibly, possibly not. Does the switch get warm currently?
I'd make one small change to the wiring diagram at the end of the link Ken posted...
I'd put the fuse between battery & relay, not t'other side. As for the fuses, a normal spade terminal fits perfectly onto the leg of a modern-style blade fuse.
any tips as to the colours of those wires? i will look in the haynes manual, but worth an ask :)
so they arrived today, goign to fit in next few days, just to confirm, as ive not looked at a proper wiring diagram since junior school when i was dangerous with a soldering iron and wiring diagrams, (with all symbols,) the symble with 85 is an earth just to check :roll:
October 7th, 2010, 11:39 pm
the symbal is in deed earth :lol:
October 8th, 2010, 7:41 am
thankyou just thought id make sure :roll:
October 8th, 2010, 9:38 am
done, very easy, and i used the old dim dip connectors from my old loom with a bit of modification, and it all works :D:D:D
October 8th, 2010, 5:46 pm
Very impressive james nice one. I just stuck the bulbs in. :lol:
October 8th, 2010, 7:17 pm
i personally reccomend fitting relays as its a doddle!!
October 8th, 2010, 9:42 pm
Users browsing this forum: No registered users and 104 guests
