View unanswered posts | View active topics It is currently April 29th, 2026, 11:25 am
Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Which Welder???
Post Re: Which Welder???
Blimey - that's thrown up alot of discussions, great....thanks to ALL for lots to consider. I like the second hand quality idea, i'm in no rush - can wait for a good one to turn up...
thanks again
July 8th, 2010, 9:03 pm
twofifty AZU wrote:
In addition to finding one that turns down low enough, I'd also look for one with a Euro torch. The nozzles and liners on the torch do wear and it makes a big difference to be able to service it.
I too have a Cebora, though its not branded Snap on. The BOC Autolynx welders are pretty good as well. No way would I spend money on a gasless MIG, having tried one I don't think I'd even spend the fuel on collecting a free one. It is just pure misery.
There are "lost" mig bottles all over the place that can be utilised if you find someone with an account BTW. I've bitten the bullet and get a bottle from Air Products, pub gas works well also.
All this is excellent advice.
July 8th, 2010, 9:43 pm
or you could go down the super cheap route
on line car boot sale
probably all thats needed is a new wire liners for the umbilical and the swan neck, a new bag of tips some wire and a few disposables....£50 or so from the on line supplier at mig forum and your up and practicing. at worst its wire liners and a new pcb for the internals
there are some other bits you can do to a sip( see the modifying Sip on the mig forum) but it ll never be up to some of the better hobby migs, but its the same as the one im lumbered with, 105, it goes down to 25A and as its 2cv biscut tin its not like your going to be laying miles of contiuous weld bead ...your dancing about tacking and joining tacks and tacking some more. ok your not going to be welding chassis section at 3mm but you shoulnt need to ;)
PS its even local(ish)
July 9th, 2010, 7:28 am
Any good?
http://www.machinemart.co.uk/shop/produ ... -010110152
December 3rd, 2010, 4:11 pm
What is a 'Non-live' torch? How does that work then? :?
December 3rd, 2010, 4:24 pm
I'd got one of those lined up for my birthday present next year - having the odd look over at mig-welding.co.uk seemed to suggest they were about the best of the cheapies. The one that Screwfix are punting for £130 atm is apparently absolute junk, by comparison.
But since having a few chats with Russ on the subject, I've been a bit naughty on fleaBay and bought a used Cebora 130 for a fraction of the price for apparently a much better machine.
Imo - by "non-live", I gather it means "non-permanently-live", so you're not at risk of scaring/singeing/blinding yourself accidentally.
December 3rd, 2010, 4:26 pm
the shroud is insulated and at no point can it carry welding current also the wire isnt live till the trigger is pulled
think its the "wolf" brand that have live torches and its easy to accidentily strike an ark before you are ready or the mask is down.
December 3rd, 2010, 5:05 pm
have a good reputation as a hobby one
( by hobby i mean its 240v single phase fitted with a 13a plug and will run off domestic power supply)
December 3rd, 2010, 5:09 pm
Twomany has the right idea, imo. If you are prepared to spend (or have spent on you...) £250-plus on a new machine, then you can pick up a superior 2nd-hand device for less.
And I'd also suggest giving serious consideration to making it a dual-purpose (gas and no-gas) one. Yes, gas gives FAR superior results by all accounts, but the running cost is significantly higher too. Also, if you need to weld outside and there's anything approaching a breeze out there, no-gas might be your only realistic option...
December 3rd, 2010, 9:46 pm
Sean wrote:
the shroud is insulated and at no point can it carry welding current also the wire isnt live till the trigger is pulled.
Which begs the question, why would one want it to be live if you weren't pulling the trigger? :? :?
December 3rd, 2010, 9:58 pm
