AAAARRGGHH! Fitting fuel pump.
Devils Advocate
 Re: AAAARRGGHH! Fitting fuel pump.
D'oh!
It all makes sense now - given that I was supplied with a cranked tailpipe, the two included straps (both of which were slightly longer than the ones that came off my straight-piped original) are obviously intended for use with the cranked pipe, and t'other way around...
So, a little swap-around is required.
Brilliant. Should all be sorted tomoz...
Cheers!
| May 26th, 2010, 10:27 pm |
Users browsing this forum: No registered users and 109 guests |
