View unanswered posts | View active topics It is currently June 19th, 2026, 2:11 pm
Reply to topic  [ 880 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 88  Next
 1-2-spark
Post Re: 1-2-spark
Excellent news - eagerly awaiting production...
January 11th, 2013, 5:02 pm
Post Re: 1-2-spark
feed for your eyes........
http://www.jetav8r.com/Vision/Ignition/CDI.html
January 22nd, 2013, 12:23 am
Post Re: 1-2-spark
tonight I put some work into the new PCB
and finished the maptab of the software.......
Now you can adjust mapadvance in 10 boxes..... (will be 20 later on for boosted engines)
a lagfactor to smoothen the spikes (if they occure)
and a trheshold when you want map advance to come in for my opinon it is better to start with mapadvance above 1250 rpm. otherwise the engine's iddle will not be smooth.....
(bouncing a little on map advance)......
Lagfator goes from 0 to 100%, so the changes in the new mapnumber calculated by the microcontroller can be ....% more or less from the old number, smoothing things out.....
Treshold (for mapadvance to kick in) goes from 600 rpm to 9999 rpm. so you can
overrule mapadvance at all making the threshold higher then the rev limiter.....
Tune the engine without mapadvance, and once proper tuned tune mapadvance......
mapadvance/retard is from +20 degrees to minus 20 degrees........
I also build in a map correction factor, when you fire up the ignition the mapsensor callibrates itselfs that normal air pressure is 100 on the gauge (in reel life it variates from 99
to 103) at my home 197m above seelevel shunshine/rain....... yes you can use it as a barometer!!!!!!!!
It takes about 0.1 to start calibrate, so it is quicker then you turn the key from ignition to starting the engine........... 8-) 8-) 8-) 8-)
January 23rd, 2013, 11:34 pm
Post Re: 1-2-spark
Looks brilliant - but now you are loosing me with all this technical stuff :oops:
January 24th, 2013, 6:12 pm
Post Re: 1-2-spark
Now...? I've been lost for 24 pages! :lol:
Hasn't stopped me reading and understanding some bits :)
Overly Ambitious Project
January 24th, 2013, 6:34 pm
Post Re: 1-2-spark
Sorry, but you need to do this to make full potential out of your turbo 2cv!!
January 24th, 2013, 7:48 pm
Post Re: 1-2-spark
When 1-2 version 2 arrives - I think you will have to talk me though all the different things. I understand without boost 1 set of timings and on boost automatically changes to other set of timings but other things !!!! :roll:
January 24th, 2013, 8:26 pm
Post Re: 1-2-spark
Now does this make sense tot you?
map against rpm table
At the left Map
underneath RPM
so you can tune every box with the best advance number.
Map 100 = normal airpressure, lower is vacuum higher is boost... you can see advance is advancing under vacuum giving you fueleconomy and retarding under boost to prevent knocking....
Do you understand this better????
January 24th, 2013, 11:58 pm
Post Re: 1-2-spark
I understand that chart - As mine goes to around 0.6 bar boost - what number would that be (130?).
January 25th, 2013, 12:10 am
Post Re: 1-2-spark
1 bar = 100kpa
so .6bar = 60kpa
= 160
if my maths is good, which it isn't.
Harls
January 25th, 2013, 4:00 am
Users browsing this forum: No registered users and 192 guests
