AZL57
 Re: Van seat belts
I know they don't have rails, but it is in that area that we did find an number unexpectingly in my friends azu.
| June 29th, 2017, 5:10 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1205 Location: Magyarország
 Re: Van seat belts
It is the same system I have in my 1974 250 . The chassisnumber in my van is in the floorpanel Rh a few cm. before the left "leg"of the rh seat . You will probably need sanding paper to find traces of the original number. Our 1965 2CV AZ had the number on the same spot. We found traces of the number, but the rest was rusted and faded .
| June 29th, 2017, 6:53 pm |
Dennis
Joined: March 24th, 2009, 9:18 pm Posts: 248 Location: 15340 Mourjou France
 Re: Van seat belts
So the chassis number could be somewhere here then?  The paint has now probably got to 2mm thick and I don't think I want to take very much of it off.
_________________ Dennis usually in the Cantal
1964 HY 72 (Type H, campervan) - LHD 1969 AZU 250 (formerly French Post Office van) - LHD 1982 Red Special - RHD 1983 Burgundy/Black Charleston - RHD 2017 Skoda Octavia Estate 1.4 DSG - LHD
| July 8th, 2017, 6:45 pm |
Geert
 Re: Van seat belts
I will post a picture of the postition of the chassisnumber on my van tomorrow !
| July 8th, 2017, 6:54 pm |
 Re: Van seat belts
Wrong corner, Dennis, you need to lift the rubber mat and look in the footwell, just in front of the passenger seat, assuming your vehicle is LHD. . So, just as Geert has advised "in the RH floorpanel, a few cm. before the left leg of the RH seat". . I'd also agree that they're usually poorly defined, since the stamping invariably looks as though it's been done without any backing... p.s. 2mm thickness of paint? Did the tin getted knocked over?
| July 9th, 2017, 12:41 am |
bobh
 Re: Van seat belts
What are the two threaded holes down the centreline of the floor panel ? Also, my AZU (With new chassis) doesn't have the angle strip between the front floor and rear cross member/rear floor and the two bolts.
| July 9th, 2017, 8:12 am |
Geert
 Re: Van seat belts
Here we go : Pictures taken from Rh side door ! Chassisnumber 2 by geert1953, on Flickr Chassisnumber 3 by geert1953, on Flickr Chassisnumber 1 by geert1953, on Flickr There might be a small dent visible , where the chassisnumber is stamped.
| July 9th, 2017, 8:30 am |
Geert
 Re: Van seat belts
bobh wrote: .............. doesn't have the angle strip between the front floor and rear cross member/rear floor and the two bolts. That is not part of the chassis, it is part of the body, if we talk about the same "strip ".
| July 9th, 2017, 8:35 am |
Geert
 Re: Van seat belts
Mmm, I think I should clean the inside of the van, it does not look so bright as yours does .
| July 9th, 2017, 8:39 am |
Dennis
 Re: Van seat belts
Thanks Geert - I've looked and the floor is in poor condition just there. I'll risk scraping the paint off at some time (OK, 2mm of paint might be an exaggeration, but there's at least as much paint as metal in some places) and see what I find.
It's not worth posting the pictures I took - they were difficult shots and they don't seem to show anything, certainly not a dent like on Geert's. I have a carpet down on top of the rubber, and I can't remove it completely without taking the seats out again, and I can't do that without moving all the cars around (again).......
I'm not entirely sure about the threaded holes, Bob, but I think they were once the fixings for a large frame that supported a front bench seat that was in the car when I got it. The bench seat could be slid forward and back a little on the fixed frame. The previous owner also supplied me with the original separate seats, which I reinstated.
| July 9th, 2017, 6:48 pm |
Users browsing this forum: No registered users and 251 guests |
