View unanswered posts | View active topics It is currently April 29th, 2026, 5:39 pm
Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3
 Earth strap
Post Re: Earth strap
I've measured a 13A (current) with engine running and all lights and radio on!
So I've just placed a 4mm2 wire in parallel with the yellow one and lowered the load.
I've Been Wrong Before.
March 24th, 2017, 11:42 pm
Radio!
March 25th, 2017, 1:07 am
Roger,
the engine & gearbox assembly is isolated from the chassis by rubber mounts to limit vibration and noise transmission, however there's a path for current to flow between it and the chassis/body unit via the driveshafts and suspension arms, isn't there?
Probably best if that 'stray current' was kept to a minimum, mind you... :roll:
Roger V wrote:
Thanks Jasu
Just as i thought. And as you say, it will find away back if it can.
March 25th, 2017, 2:00 pm
Thanks Ken (everyone)
Earth strap has arrived. Not fitted because have been dealing with the oil leak.
I probably won't notice any difference when I do, but I will know it has one. :D
Then there's the charging issue to sort out!
March 25th, 2017, 2:15 pm
Earth strap fitted
Charge appears to have raised to 14.4v at the battery
Voltage indicator on the dash is still in the grey zone!
Hmmm
March 25th, 2017, 5:24 pm
Roger V wrote:
Earth strap fitted
Hmmm
You could do with a new voltage indicator I guess.
Or did you swap it already ?
March 25th, 2017, 6:31 pm
I'm gonna look for threads on this. Any help or direction is appreciated. :)
March 25th, 2017, 10:10 pm
Roger,
14.4 volts should be fine as the target charging voltage for a lead-acid battery, although any higher than that and the battery will start to 'gas'.
As Geert has already advised, I'd trust your multimeter rather than the original dash-mounted voltmeter in the car, which can lose its accuracy with time...
March 26th, 2017, 1:57 am
