ChrisW
 Re: Drive shaft in a tiz
But couldn't the pin come out of the arm if its loose
| September 16th, 2015, 9:26 pm |
Not sure why, but from what I've seen, a kingpin which is a loose fit in the arm always moves upwards, never downwards.
If the resultant scraping, graunching noises are ignored for long enough, the pin can grind so much metal off the constant velocity joint's casting that the outer driveshaft needs to be replaced...
| September 16th, 2015, 9:55 pm |
Users browsing this forum: No registered users and 208 guests |
