View unanswered posts | View active topics It is currently June 19th, 2026, 2:47 pm
Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3
 Heater Tube Alternatives?
Post Re: Heater Tube Alternatives?
smyth602 wrote:
AZS wrote:
As with most things on the 2CV, Citroën did quite a good job in selecting the heater tubes. I experimented with alternatives but now gone back to the original.
I agree that for the most part, Citroen indeed knew best, but i find that the standard heater tubes are a massive pain in the ass to fit, are a real fire hazard being cardboard and so close to the exhaust and for one of the tubes my handbrake rubs it on the bottom and the heater control rubs on the top, causing them to wear out very quickly and making the heater controls difficult to move.
All of the above combined are enough to make me at least investigate alternatives that didn't exist when the 2cv was created.
The only tubes I've seen set alight, weren't properly mounted and as a result, had fallen onto the exhaust.
Before fitting the tubes, compress them as far as possible before cutting them to length (if at all necessary) usually they fit without cutting. This way the tubes will never fall off, if you still don't trust it, just use some tie-raps to mount them on the adjuster cable and the flat metal strip near the handbrake.
For the places that get rubbed trough, you could maybe tape or glue a metal plate onto the tube.
The foam inside in the original tubing is essential in absorbing part of the noise.
July 30th, 2014, 2:56 pm
Somebody suggested running a wire through the middle screwed to the heat exchanger and heater duct which will stop it coming off.
July 30th, 2014, 6:36 pm
I put old vacuum pipe up the inside of originals to stop them collapsing internally but also killing the noise, I also have two computer fans in the bulkhead inlets to blow some air over the screen initially..
August 4th, 2014, 8:04 pm
Well, I managed to line the new neoprene hoses last night. Small ones with a length of hollowed out swimming woggle and the big ones with some high temp spray adhesive and some packaging foam sheet.
First test show the air flow is amazing, judging by the amount of crap that blew out of the window vents.
Full test tonight!
August 5th, 2014, 11:12 am
Haggis Muncher
I'm still swithering about returning the stuff i got and just sticking with the originl tube but doing something more to secure them... any more results to post?
August 5th, 2014, 10:59 pm
50 mile round trip, it's ace :)
August 5th, 2014, 11:04 pm
