View unanswered posts | View active topics It is currently June 20th, 2026, 1:34 am
Reply to topic  [ 30 posts ]  Go to page Previous  1, 2, 3
 alternators and gearboxes...
Post Re: alternators and gearboxes...
No idea what Andy's used, but no need for it to be from a citroen. Correct me if I'm wrong, but ALL alternator pulleys were similar until they started using multi-rib belts, it would be best to keep to something similar diameter, but not critical. Too large a diameter it'll turn slower and won't charge at idle, too smaller diameter it'll turn quicker, might overheat?
If it's from a completely different engine the brackets will most likely be different, you can make up brackets so it fits, but do it properly so it's reliable.
If you're lucky the local scrap yard will have a shelf full they'll let you browse until you find something that looks like it'll fit with out too much work.
Thinking about it, I missed the point of this thread, why aren't you putting a second hand original one on?
February 1st, 2014, 11:58 pm
Haggis Muncher
I seem to remember a conversation with Andy in a field many years ago that makes me think its a Saxo one.
February 21st, 2014, 10:03 pm
If you're the local scrap yard will have a shelf full they'll let you browse until you find something that looks like it'll with out too much work.
as citroen didnt make alternators, they made the engines fit the alternator. im not 100% but pretty sure there are mostly the same dimensions and designed to be driven by the same belts. the bolt hole for the tensioner can be moved in relation to the fitting hole by moving either one of the end caps round by a bolt hole.
February 21st, 2014, 10:33 pm
lovin' the snatch
got to be atleast 40A, original 2cv where 30A, the 40A ones ecas sell are Valeo - GS 40A which is what i have however its been "tampered" with by a friend.. so hes called of my father... however i've seen a replacement rotor/shaft for my alternator for decent money so i'm going to buy that instead! :) already have my new regulator now!
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
February 24th, 2014, 4:55 pm
Bargain :shock:
http://www.ebay.co.uk/itm/QH-ALTERNATOR-RC676011P-TO-FIT-CITROEN-2-CV-0-6-79-90-OE-QUALITY-/291053622417?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3A2+2cv&hash=item43c425d491
February 25th, 2014, 7:34 pm
I've gone with this one. 181328995063. 60 amp.
http://www.ebay.co.uk/itm/Denso-19630-6 ... 7675.l2557
February 25th, 2014, 9:27 pm
Well it is from Somerset,probably need the money :roll:
February 25th, 2014, 10:46 pm
Water damaged stock?
February 25th, 2014, 11:02 pm
:shock: That was cheap, was that the error in the listing that made him pull it.
February 25th, 2014, 11:17 pm
They have been cheaper but the price has gone up,because the kit car boys are snapping them up as they become available.live bought one it comes with it's plug and built in regulator I will be fitting it once I get the MSVA sorted.
February 26th, 2014, 7:18 pm
Users browsing this forum: No registered users and 243 guests
