View unanswered posts | View active topics It is currently June 19th, 2026, 11:57 pm
Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Oil leak
Post Re: Oil leak
That would be someone who did not know the significance of the breather.
Remember ... this is boxer engine and not all engines suffer so much ...
April 3rd, 2013, 9:48 pm
Post Re: Oil leak
Ok so, new (standard) rear crank seal fitted ... still pissing out oil though :cry:
This leak was detected when the engine was cranking over and not actually running.
Before I go down the route of an oversized, (or would that be under sized) seal (thanks for the suggestion Sean), is there anything else I should check. Bear in mind this engine has been rebuilt by someone else and this is the first time it has been run.
April 10th, 2013, 4:15 pm
Post Re: Oil leak
Are you sure it is the oil seal and not the 2 faces of the block. As you have not done the rebuild yourself - do you know if sealant used between mateing parts. Also oil pump there. gasket in place.......?
April 10th, 2013, 4:31 pm
Post Re: Oil leak
Dave,
as with any other parts, doesn't the rule of 'replace when not working correctly' apply?
If they've never been overheated or choked with excessive blowby, I find that they work as they should for a lot longer than that randomly chosen figure of 5 years.
dave 411 wrote:
Who would rebuild an engine and not fit a new breather :roll:
April 10th, 2013, 4:36 pm
Post Re: Oil leak
Hi Chris
It does look like it is coming out between the seal lip and the crankshaft and it only leaks when the engine is turning over or running so I guess this is when there is oil pressure.
I have never had one of these engines apart, so seek advise, if a component could be fitted incorrectly and blocking an oil way thereby forcing oil past the seal!
April 10th, 2013, 4:58 pm
Post Re: Oil leak
I believe that the oil comes from the oil pump and straight to that bearing via a tube moulded into the casing. Did you set the seal in correctly - outside edge 0.5mm inside casing. Very easy to push it in too far and then the seal deforms leaving a big gap to the crank.
April 10th, 2013, 5:37 pm
Post Re: Oil leak
Chris
Damn .... I pushed it right back. :cry: You may have hit on the issue here.
So .... how can I pull it back out ... any tips! I did put it in with grease ....
April 10th, 2013, 5:46 pm
Post Re: Oil leak
Dave,
I agree Ken, however had I'd purchased a "rebuilt" or "reconditioned" engine at some of the crazy prices on eBay I would, on the list of new parts, expect to see a new breather.
It's all about lexis ;)
April 10th, 2013, 6:22 pm
Post Re: Oil leak
Dave,
Hi Ken,in this instance,I would most deffo fit a new breather.Having spent all the time and money on a re build,i would say its just the thing to do :|
April 10th, 2013, 6:28 pm
Post Re: Oil leak
Roger V wrote:
Chris
I think you will have to scrap that one and remove with screws etc as per the first one. SORRY
April 10th, 2013, 6:34 pm
Users browsing this forum: No registered users and 231 guests
