View unanswered posts | View active topics It is currently May 2nd, 2026, 12:52 am
Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Bullet connectors
Post Re: Bullet connectors
Again a crimping tool - you get what you pay for..
I bought one in halfords - a week later there was a mm gap between the wire cutters!!
January 9th, 2013, 8:43 am
Haggis Muncher
Trying an experiment:
Vinegar + salt = acid. dip corroded terminals in solution, wait 5 minutes, give light scrub with toothbrush then dip into baking powder solution to neutralise (alkali).
In theory this should remove the corrosion on the terminals, then i only need to replace the sleeving. Ill post results soon!
January 9th, 2013, 9:21 pm
Haggis Muncher
It seems to work! They don't come up as good as sanding them, but if someone can tell me how to thoroughly sand the inside of a female bullet connector i'll be impressed :p
January 9th, 2013, 9:39 pm
Bearing in mind how much surface area there is on a Citroen style bullet connector, I doubt that they've got to have the sort of shine that you find on pub or church brass fixtures, simply removing any surface corrosion is usually sufficient.
It always amuses me when folk write about how sanding/polishing the LT connections on their coil has transformed starting.
Must have been in a fairly grotty state previously... :roll:
A 4 or 5mm diameter bolt shank in a battery powered drill seems to work for me, but if you really want to go for it, how about some of these? :lol:
http://www.ebay.co.uk/itm/4mm-x-160mm-R ... 53f16161d1
Don't forget the light coating of copaslip grease or petroleum jelly afterwards...
Much the same story on the much-maligned Citroen fuse box, except that's where a small chainsaw file comes into play to clean up each terminal, then refit it into the fusebox.
January 9th, 2013, 10:31 pm
Haggis Muncher
Haha, I think polishing them is going a bit far :lol:
The terminals on my van were pretty horrendous though due to a water leak that lands right on the dash. They were to the point that when I dismantled the headlight stalk i literally couldn't see any copper :o
Good tip on the chainsaw file - i have about a million of them lying about the place :)
January 9th, 2013, 10:44 pm
I find the wire brush attachmet on a dremel brings them up like new in second!
January 10th, 2013, 1:07 am
Haggis Muncher
Did you ever get your ebay sleeving, ken? Did it work out ok? Curiously waiting here :p
January 18th, 2013, 12:29 am
The simplest reason for the loom to retain the standard-style bullets, over spades or aftermarket bullets, is that you don't need to change the terminals on everything that the loom connects to.
If you're replacing the rear lights with hideous generic trailer ones, then - sure - you might want spades for that. But it's a bit trickier to replace the connectors on old-style wiper motors, or all the dash gubbins, or...
January 18th, 2013, 1:49 pm
Aye,
I did, but would opt for a thinner walled version next time round.
Got 4mm ID x 7mm OD for the smaller connectors and 5mm x 8mm for the larger ones.
http://www.ebay.co.uk/itm/261112388696? ... 1439.l2649
Might try 4mm x 6mm for both sizes next time, but that could be a while... ;)
January 22nd, 2013, 10:32 pm
Aye,
Photograph below is 4mm x 7mm on one of the larger bullet connectors.
Might try 4mm x 6mm for both sizes next time, but that could be a while, which would also help see how it stands up to conditions in an engine bay... ;)
Clear silicone tubing as sleeving on bullet connectors by slcchassis, on Flickr
