Reply to topic  [ 29 posts ]  Go to page Previous  1, 2, 3
 Making of....... a sandblasting Cabinet
Post Re: Making of....... a sandblasting Cabinet
75 liter tank, 200l/minit, 10 bar, should work I guess.... (you can see it in the background)
attached to the wall!!
November 11th, 2012, 2:34 am
great stuff ipgo it won,t be long till you give it a test, will u be using sand? apparently b&q do kiln dryed sand by the bag
November 11th, 2012, 2:23 pm
Post Re: Making of....... a sandblasting Cabinet, first result!
First testresult stop.
Great stuff stop.
First pic now and I'm off again "blasting"stop.
More later....stop.
November 11th, 2012, 3:36 pm
total sucsess!
November 11th, 2012, 7:09 pm
I found that the real key to longevity and reliability is keeping the air supply and the cabinet as dry as possible. Maybe run the compressor for five minutes before using the tank to remove the condensation from it, and drain the tank regularly. My sandblaster is always clogged up because our compressor fills up with water like mad. I've got two water traps on it but its hopeless. I used to use crushed iron at my last job and that stuff is great but very abrasive and obviously any moisture in it spells disaster.
November 11th, 2012, 7:25 pm
Russ you are right, its the same over here, had the compressor running, no condense coming out. Put some crushed iron to it and had only condense the first 10 seconds...
but after that it works great here a video
https://www.youtube.com/watch?v=opoM2dc2CYw
I think I need a nearower??? hose to pick up the crushed iron, and a decent filter to let the air out and keep the material in but other then that it's running great :D :D :D :D :D :D
November 11th, 2012, 8:07 pm
What about a second-hand vacuum cleaner from a junk shop? A filter from a scrap car or similar too.
November 11th, 2012, 8:18 pm
Well what a coincidence I've got some airfilters from an old Citroen 2cv. Do you know those cars ;)
November 11th, 2012, 8:26 pm
I'm aware of them, yes.
November 11th, 2012, 8:28 pm
