View unanswered posts | View active topics It is currently November 20th, 2025, 5:50 pm
Reply to topic  [ 21 posts ]  Go to page Previous  1, 2, 3
 Running issues
Post Re: Running issues
Viking,
sorry, but why would that tiny gap have any significance?
If the secondary butterfly isn't sealing properly at tickover, any 'false air' which leaks through it has a much more direct path into the intake manifold. :?
Citroen never fitted paper gaskets when the cars were new, either between the carburettor and the insulator block or between the block and the manifold.
As long as the base of the carburettor isn't warped (because the nuts have been overtightened) and the block is in good condition, extra gaskets are not necessary.
Also, a warped carburettor base can soon be sorted with a good file and some careful work... ;)
2CViking wrote:
Manifold gasket
I would place the gasket between the manifold and the spacer. You are creating a brigde between the butterflies unless you fit one of these
June 4th, 2012, 12:39 pm
