james2cv
 Re: Engine Compression
Little Louis wrote: ken wrote: James, I hope you're going to check the maximum advance with a strobe as and when you fit 123... Had a call from a specialist in Manchester today who was fitting one and when he checked the maximum advance, it was about 50 degrees. He tried another new one and it was exactly the same, so he had to resort to fitting a s/h unit, which gave the required 33 degrees. Guess who's car it was! Yep. It's been done, and I can officially say that it is running the best I've ever known it to. No pinking so far (ok only done 30 miles), but in terms of driving I really didn't expect things to change, but it seems to pick up miilllles better in 2nd and 3rd, generally seems quieter and all round smoother. I'm not suggesting that 123 is better in anyway than well set up points, it's probably just that mine were set up proper shit or there was something up with the weights? Oh, and he also set up the tappets and the compression evened itself out abit. Anyway deffo no major lack of power, so I'm not worrying.
| August 24th, 2011, 10:20 pm |
james2cv
p.s. I proper need to learn to do all this shizz myself.
| August 24th, 2011, 10:21 pm |
Lil'Louis, how many guesses have I got as to *whose* car it was? Also wonder where I should send the invoice for consultancy, for time spent on the phone when I should have been welding, etc., etc. ... Just as well that Alan M checked those 123 units with a strobe, James would have been deafened with the pinking at 50 degrees maximum advance. ken Little Louis wrote: ken wrote: James, I hope you're going to check the maximum advance with a strobe as and when you fit 123... Had a call from a specialist in Manchester today who was fitting one and when he checked the maximum advance, it was about 50 degrees. He tried another new one and it was exactly the same, so he had to resort to fitting a s/h unit, which gave the required 33 degrees. Guess who's car it was!
| August 24th, 2011, 10:37 pm |
J-dub
James, all this sort of stuff is easy, read the haynes manual, and try it, setting up points is as easy as changing a plug once you have marked the flywheel where to set the timing (i marked fly wheel and starter to make two reference points) you want it 4 teeth after firing point? i cant remeber, but anyway someone will confirm, easy as pie
| August 24th, 2011, 10:47 pm |
James, left side 'horn' of the engine casing is better, as there's less chance of parallax interfering with accuracy. A pointer screwed onto the engine casing makes things even easier. http://www.flickr.com/photos/30132857@N ... hotostreamSlightly over 7 teeth for an 8.5:1 engine, just under for 9.0:1... ken Jameswallace wrote: James, all this sort of stuff is easy, read the haynes manual, and try it, setting up points is as easy as changing a plug once you have marked the flywheel where to set the timing (i marked fly wheel and starter to make two reference points) you want it 4 teeth after firing point? i cant remeber, but anyway someone will confirm, easy as pie
| August 24th, 2011, 11:19 pm |
J-dub
ahh thanks ken well it was bell housing and starter motor i used with tip ex
i think what i describe i use is what you describe? not sure
| August 24th, 2011, 11:47 pm |
Rhythm Thief
ken wrote: James,
@ Rhythm Thief. I don't think that new advance weights will make any difference to the rate at which electrical erosion of a set of points occurs. That's more likely to be affected by a substandard condenser or charging system voltage being too high.
ken. No, quite right. But it will affect whether or not the thing pinks under load.
| August 25th, 2011, 1:11 am |
james2cv wrote: p.s. I proper need to learn to do all this shizz myself. garage 5/6
| August 25th, 2011, 9:00 am |
Rhythm Thief
Sean wrote: james2cv wrote: p.s. I proper need to learn to do all this shizz myself. garage 5/6  You're going to have a busy weekend doing all these cars Sean, what with the whole team consisting of you and two drivers.
| August 25th, 2011, 9:13 am |
Rhythm Thief wrote: It might be that your advance weights are worn. I usually check them when I'm doing the points on an engine for the first time. They do wear and new ones (under £30 from the usual place) make a big difference.
which bits wear, what do you look for, how do you test them and what's an acceptable state? just to keep the whole thing mechanical rather than conjecture we had been doing some stuff on bob weights and how the different makes affect the advance curve and what modifications did what to the engine. there was no conclusive outcome ........mainly because the dyno broke.
| August 25th, 2011, 9:17 am |
Users browsing this forum: No registered users and 118 guests |
