Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 slowbo no run , job done all sorted
Post Re: slowbo no run / engine now run's , gearbox/ clutch no wo
No FBC'S ? :lol:
July 13th, 2011, 7:44 pm
Captain Slow
so been trying all day , got it into 1st and drove round the block with no luck , then got stuck in reverse for a bit , its now in 2nd gear tried moving on drive way with handbrake on to free it , just starts burning the clutch big time
shall i just keep going for it ? or is it time take the engine out and sort it that way ??
July 14th, 2011, 6:40 pm
If the clutch is burning it must be slipping. Maybe the splines are clagged up causing the gears to crunch. I think you ought to bite the bullet and take it out.
John Jordan
July 14th, 2011, 6:45 pm
Go for it, if its that bad it will need changing. Bet Pongo has got time on his hands.
July 14th, 2011, 7:00 pm
How long does it take to do a clutch? hour and a half? With all those Facom tools you love it'll be a piece of piddle man.
July 14th, 2011, 7:26 pm
Oboe,
Out of interest, is this the car you brought from Mr Cotterall in Derbyshire ?
Maybe with wooden floors ?....if so I have some pics of its re-build.
However :
1) I might be totally wrong
2) It wont help you at the moment
3) ;) Good luck !
July 14th, 2011, 8:38 pm
Captain Slow
Code:
Oboe,
However :
3)   Good luck !
no its not that i no off , jono had a 2cv with wooden floors once i think
mine E77 CDV
July 14th, 2011, 9:02 pm
Are you sure its the clutch smelling and not the brakes?
Sounds like the spigot shaft is seized in the flywheel bearing - might not come apart as easy as you think.
Alternatively you might be not have been rough enough with it yet! - More "Rodeo Style Kangaroo-ing" required.
July 14th, 2011, 9:03 pm
Nibby_Pit wrote:
Sounds like the spigot shaft is seized in the flywheel bearing .
if that was the case then surely the clutch pedal wouldn't depress, would it ?
July 14th, 2011, 10:16 pm
Will someone tell him :D
Thought I'd better qualify that. Seized spigot bearing will not stop pedal depressing, but will cause gear crunching cos engine will still be turning input shaft.
John Jordan
July 14th, 2011, 10:19 pm
