View unanswered posts | View active topics It is currently May 1st, 2026, 4:28 pm
 2CV rear axle stub nuts
Post Re: 2CV rear axle stub nuts
EirikJ wrote:
I just use this, to get the rear drums off. Have always worked for me, but maybe I haven't met the really stubborn ones yet:
You could have taken a picture of my stuff its identical !
have mastered the art of standing on the end of the breaker bar and clouting the socket with a hammer at the same time- for that i use the bigger hammer thats not in your picture ;)
April 17th, 2011, 9:32 am
I've had a look in the workshop manual, and it seems as these should only be tightened with 35-40 Nm,greased threads.
Just remember an axel stand to support the swing arm. 35-40 kg pushing downwards can damage the swing arm stop
April 17th, 2011, 10:47 am
Whats the thread size on that 44mm nut? anyone? thanks, Paul
April 17th, 2011, 11:49 pm
Uncle Roy says "M34 x 1.5"
http://www.ecas2cvparts.co.uk/wheel-hub ... -1381.html
April 17th, 2011, 11:54 pm
Found this die in the US. Not cheap but lovely to have and use. Threadfiles are ok but fiddly to work with, they work better on inside threads like drum bearing ríng nuts etc.
http://www.2cviking.eu/catalog/product_ ... cts_id=759
April 18th, 2011, 9:36 am
Thread files don't work on internal threads at all, the splines run in the wrong direction. Nor for that matter are they "fiddly" to use.
If you want to mildly re shape an internal thread you need a thread chaser.
April 18th, 2011, 10:59 am
Umm, for the _internal_ thread, wouldn't you just buy a new nut?
April 18th, 2011, 11:08 am
WHAT!
How do you clean the thread on rear drums then (ring nut thread holding the wheel bearing)
April 18th, 2011, 11:16 am
2CViking wrote:
WHAT!
If that was to me, then - you're right, I'd forgotten about that one. But that wasn't the one we were talking about, was it?
April 18th, 2011, 11:30 am
Well I use a thread file to ''repair'' a buggered thread front or rear wheel bearing ring nut thread.
April 18th, 2011, 11:34 am
Users browsing this forum: No registered users and 99 guests
