View unanswered posts | View active topics It is currently May 1st, 2026, 8:48 pm
 Breather Overhall
Post Re: Breather Overhall
Silicone rubber that they make cooking stuff out of nowadays:
http://www.youtube.com/watch?v=gZYJWDQzYR8
Not any kind of coated steel.
April 25th, 2011, 2:44 pm
no the rubbery stuff comes in bright colours
April 25th, 2011, 4:38 pm
I assumed it was all the same stuff. I might have posted the wrong link I thought it was a fella with some rubbery silicone cooking stuff?
April 25th, 2011, 5:47 pm
tried this, but seems to floppy.
http://cgi.ebay.co.uk/Gasket-Silicone-R ... 500wt_1156
April 25th, 2011, 6:09 pm
We're out of synch
the no was for non stick tinware
Pete thats the stuff instead of just riveting it down, the pop rivets compress it too much and it buckles up, i made sort of lozenge shaped spreaders that held it all flat.
Ill do pictures of the next one but got brakes to sort out first :lol:
April 25th, 2011, 8:21 pm
Quick question: How thick does this "silicone" sheet have to be? If you need it to be as thin as possible, you might prefer to use "baking sheet foil", which is very thin indeed, is coated with teflon, and is good for temps up to 260C. It feels like a sheet of plasticised paper. The silicone sheets are thicker and more rubbery.
I'll post up a pic if you think it would be of help.
Incidentally, I've seen both products in Lidl and Aldi recently.
April 25th, 2011, 8:24 pm
thats the secret source busted then :lol:
and TKmax usually has a selection of rubber bakeware too
first one i did used thinner stuff, had the diaphragm held down with wire clips and it sucked like Hugh Grants "friend"
second used thicker stuff and had steel plates and pop rivets but i didnt test it.
have 5 towers to do over the next few days so will stick one on the blue thing and see what happens have to get a new gas bottle in the meantime though.
April 25th, 2011, 8:34 pm
Sean,
Yep, had the problem with the rivets, tried small nuts and bolts, didnt test.
Current bit under test...spring steel....pop rivets go in holes.... all very, very fiddly
April 25th, 2011, 8:44 pm
thats almost the same as i did
the blue steel is the same shape as i made, 4mm hole in the centre, these were then riveted over the silicone sheet where your more silvery metal was
much simpler and worked a treat.
i also normalise the flange and crimp it back over using either silicon or PU sealant.
just need to get some 27mm ID silicone pipe
April 25th, 2011, 8:52 pm
Sean,
Silicone pipe can be ££.
Swap?
My "repair flange" kit for
Wing valence panel, 2cv front right.
Removable panel between wing and bonnet.
Part Number: 85262A
April 26th, 2011, 9:55 am
Users browsing this forum: Bing [Bot] and 87 guests
