View unanswered posts | View active topics It is currently April 29th, 2026, 3:13 pm
 Loud screachy Noise from Somewhere!!
Post Re: Loud screachy Noise from Somewhere!!
Matt da cote wrote:
Anyone got a spare Engine 1220 or 1299 and a 4 speed box I could have??
Why do you need to swap the engine?
Box, yes - I wouldn't be trusting that input shaft. I suspect somebody let the engine's weight sit on it whilst trying to persuade that incorrect clutch to mate up.
December 9th, 2010, 9:24 am
Well that was me with the incorrect clutch, some cock at the local motor factors place sourced that for me...Looked right and fitted on nicely, but obviously the wrong one...and engine crane was used in the removal and re-fitting....I dare say in its 6 years or so sitting in people back/front gardens..the engine must of been removed a few times!!!!!!!!!!!
I would like a spare engine just incase i suppose, Or one I could strip down and rebuild knowing it might last a while, Knowing my luck something will happen to the engine next!!!Just covering my Back really!!
I've heard whispers that there is a Gearbox guru somewhere around on one of the forums, does anyone have a contact for him, As It might be worthwhile getting the gearbox I already have rebuild rather than try and found another one...If you know what I mean!!
And jon (spanners) did say that this one was fitted with a lower ratio 4 gear or higher can't quite work it out in my head at present, anyway so it didn't run out of steam till you were at the wrong side of 100mph!!!!!
Dyane 12 1976 (ish)
December 9th, 2010, 4:12 pm
There really is only one person to talk to for G bits.
Rob Moss at Chevronics - http://www.chevronics.co.uk/
Rick Pembro - http://www.gearbox-guru.co.uk/
That'll be higher ratio, then. Higher road speed for the same number of revs.
December 9th, 2010, 4:23 pm
At least you've found the source of the noise. I love it when you take something apart to find a problem and it's glaringly obvious what the problem is.
December 9th, 2010, 7:15 pm
Get the box to me and I'll tell you what you need to order, fit the bits and you can have it back......
GS boxes are a piece of piss! :geek:
December 9th, 2010, 9:00 pm
How much roughly you think a gearbox weighs?? Could get it courier to you Jon..Might cost a bit though!!
Dyane 12 1976 (ish)
December 10th, 2010, 1:11 am
Snail Trail?
viewtopic.php?f=4&t=1790
December 10th, 2010, 8:12 am
Users browsing this forum: No registered users and 82 guests
